Hub Firmware Release Notes - 0.24.11
About 3-5 minutes. I should add I’m not convinced just yet that there isn’t still something wrong with the Cree updated FW. I had to do the power cycle again this morning as I lost some of my Iris sensors again. It is known that Crees are not strong repeaters BUT I had no issues with mine before this Cree FW update. And it could also be true that the hub FW update is related too. I just don’t have the data points to know.
Right now it’s holding but only time will tell.
Listen to @bamarayne from an old timer as well. Halloween time has been the roughest for all of us over years. God knows where @SBDOBRESCU aka Bobby has disappeared but he was the guy with “the” Poltergeist which appeared almost ever for past 4 yrs. I have pretty much moved my automations to native apps. Ecobee, Philips Hue ecosystem, Alexa, Apple HomeKit etc. and pretty much have couple of beers rather than spend time on fixing ST and whining.
It seems part of the firmware update has also been to update the firmware in ST sensors. This update has probably hammered the sensor batteries.
This is certainly true. I have a couple of ST multisensors, going back through the logs I can see that before the update one was at 100% battery, the other at 78%. After the sensor’s firmware updates (you can see the start and end of the f/w update by looking at the sensors event listing in the IDE; each took about an hour to update on my network from beginning to end) the 100% battery went to 50% (since rebounded to 67%) and the 78% battery went to 1% and stayed there. It’s definitely shot because the multisensor is doing the typical thing it does when its battery is weak-- giving a steady stream of false vibration events.
Probably a good idea to turn OTA updates ‘off’ for this reason alone if you are leaving your house unattended for a while. Even if your hub continues to work fine after an update, you don’t want your sensors to die unexpectedly while you are away should a new sensor firmware be part of the package.
Old Timers??? lol
Yeah, I’ve spent a lot of time writing my own apps to do things the exact way I want them too… plus a lifetime in the navy taught me all about redundancy… I have automations in the cloud and backups with the local running stuff for most of it… Just takes times and a whole bunch of patience.
Hard to run native apps to control GE Zwave switches and dimmers that are now unresponsive, but are somehow reporting temperature and lux levels in app and IDE lol.
:rofl::grin:
I use webcore for the majority of my automations and have quite a few issues the last 2-3 days. Pistons that don’t trigger because they miss events, or pistons that do trigger but the action never happens, etc. It’s intermittent and seems to affect all pistons randomly. For example, when I hit my sleep button to shut down the house a few minutes ago, first time it didn’t trigger the virtual switch, second time it did but nothing else happened, 3rd time a few of the lights turned off, 4th time finally everything turned off correctly. This has just been the last few days, I’m assuming it’s 24.011 related. Anyone else seeing similar?
As soon as the beta is released to public centercode projects are removed till the next one
I live in a modest 1969 built house so, do not have the luxury of having those switches. I live in a Philips Hue Ecosystem along with their bulbs, motion sensors, dimmer etc. Their app keeps getting better and better.
I’d like to note the same issue with the battery drain on the Samsung multi-purpose sensors. I’ve never had an issue with batteries and they lasted 6+ months without any issues. However, I’ve got these gems in my logs after the firmware updates:
[Battery was at 100%]
2018-10-12 5:53:34.854 AM EDT
2 days ago	DEVICE		firmware	0x1F015310		Sensor - Front Door firmware update started
2018-10-12 6:40:42.633 AM EDT
2 days ago	DEVICE		battery	1		Sensor - Front Door battery was 1%
[At this point I plugged in a new battery]
2018-10-12 9:59:20.304 PM EDT
2 days ago	DEVICE		battery	100		Sensor - Front Door battery was 100%
2018-10-14 8:42:34.303 AM EDT
1 hour ago	DEVICE		battery	83		Sensor - Front Door battery was 83%
17% drain in 2 days? Yeah, I don’t feel like changing these once a week.
I was removed also.
Also - notifications are now severely delayed. I use ST to notify me when someone rings my Ring doorbell. It was immediate before the update and now it is 3-4 minutes delayed!
Hi I’m using a V2 hub and the SmartThings app. Account was new and opened in 2018.
Previously, things were working great, but today I opened the app and my hub and devices have disappeared.
I emailed support, but if anyone has any hints please let me know. I think it must be related to the new smart things classic app or this hub firmware update. Everything was working beautifully before.
My router shows my hub is online and green light is on. If I go to the hubs IP, the page doesn’t load (can’t remember if I should see a page or not). Developer site also does not show the hub or devices anymore :frowning: Thankfully all my custom device handlers and apps are still there.
login to IDE at https://account.smartthings.com and check to see if you might have two Home Locations
Just one Home under Locations in the developer portal.
there is no page
Didn’t even know there was a firmware update. I missed the email I guess. Where to start:
Newer version SmartSense Multi Sensor went into fw update then fell offline, pull battery, next day it starts auto fw update again, same thing offline. Wonder how long this loop will continue.
  • Current Version: 0x00000009
  • Target Version: 0x0000000B
  • Last Updated: N/A
  • Last Checked: 2018-10-13 8:10 PM PDT
[2018-10-13 8:23:28.020 PM PDT
12 hours ago ]DEVICE activity offline Your SmartThings device Zstorage is now offline
[2018-10-13 8:22:27.021 PM PDT
12 hours ago COMMAND ping ping command was sent to Zstorage
[2018-10-13 8:22:27.020 PM PDT
12 hours ago ]COMMAND ping ping command was sent to Zstorage
[2018-10-13 8:10:14.256 PM PDT
12 hours ago ](DEVICE firmware 0x00000009 Zstorage firmware update started
[2018-10-13 8:10:13.017 PM PDT
12 hours ago ] DEVICE firmware 0x00000009 Zstorage firmware update started
[2018-10-13 8:10:11.229 PM PDT
[2018-10-13 8:10:09.959 PM PDT
[2018-10-13 8:10:08.204 PM PDT
12 hours ago DEVICE activity online Your SmartThings device Zstorage is now online
[2018-10-13 8:10:08.175 PM PDT
Older version Smartsense Motion Sensor (2015) fell off network twice in two days, Not fw update related. Had to pull batteries twice in two days, it’s 6 feet above the ST v2 hub.
  • Current Version: 0x1F075310
  • Target Version: 0x1F075310
  • Last Updated: N/A
  • Last Checked: 2018-10-13 11:40 PM PDT
Wife reports bed side Cree Bulb lamp started flashing in middle of night. But recent fw update was in the afternoon.
  • Current Version: 0x0000020A
  • Target Version: 0x0000020A
  • Last Updated: 2018-10-11 4:33 PM PDT
  • Last Checked: 2018-10-14 7:38 AM PD
Aeon DSC06106-ZWUS switch randomly turned on while I was in the room. No app activity/history. Just turned itself on yesterday during a time where I was replacing ISP cable modem (i.e. hub going through lots of connects/disconnects).
2018-10-13 10:03:11.410 AM PDT
23 hours ago
DEVICE switch on 3D Printer switch is on true
Five older z-wave switches, some on opposite sides of the house went offline/dead overnight yesterday afternoon and last night.
try logging out of the app and then log back in
no luck there either…
just for fun, download the other app, login and see if anything shows. so if you are using the Classic app, try the Samsung Connect app or vice versa
