How to set up home to randomly turn lights on and off when on vacation?
Is there a way to set up the Smart things hub to randomly turn on Lights and things while away. Or do I need to set up a Routine for each light and and outlet. I want to give it an appearance that some one my be home.
There are a couple of custom smart apps that can do this, including the popular ā€œvacation light director.ā€
If you haven’t used custom code with smartthings before, it’s pretty straightforward. Basically you copy someone else’s code and paste it into your account. Here’s the FAQ for that process:
If after looking that over it sounds like something you’d like to try, you can check the quick browse list for ā€œlightingā€ under smart apps in the community created wiki and see the various custom code that community members have contributed. ā€œVacation Light directorā€ should be in there.
http://thingsthataresmart.wiki/index.php?title=How_to_Quick_Browse_the_Community-Created_SmartApps_Forum_Section
I use the CoRE app to do this for me.
Here’s a screenshot.
Works well for me and you can set how long the lights are on for and the 'randomness ’ according.
Here’s my CoRE version for away/vacation lighting that randomly selects one of three lights to turn on/off:
Hey, how’d you get it to be ā€œimmediatelyā€ for your variable setting? I can’t figure it out!
@elf thanks!
Vacation Lighting Director SmartApp is available from Automations>SmartApps>Add a SmartApp>Lights and Switches.
Mmmmm … that’s a REALLY old version of my Away Lighting … I didn’t even recognize it since I completely rewrote it, LOL. I don’t think ā€œFollow up with pistonā€ is even a valid wecCoRE command anymore …
Would you need able to post a backup of your updated piston so it can be imported?
Thank you!
Here’s what I’m currently using … easy enuf to change time requirements, add lights:
Hi. I don’t see the vacation lighting director in this path you specified. do i have to install something to get it to show up?
It’s in Marketplace not Automations then follow as directed
Thanks, Bob. I went to marketplace>smartapps>lights&switches but i dont see it there either. I then scoured the entire marketplace smartapps section and i still dont see vacation lighting director. this should be simple, but i’m feeling a bit defeated by this :frowning:
IT’S GONE.
Must admit I didn’t find it reliable.
I use webCoRE now.
Here is a simple one I use.
Thank you for helping me confirm i’m not crazy. i wouldn’t begin to know how to use code with smartthings. can you provide me with a n00b instruction page i can review to get it setup? btw, thanks for taking the time to help.
Bob - forgive me for the dumb question but can you tell me how to import this into my WebCore? Not done it before.
When creating a new piston, select the option RESTORE A PISTON USING BACKUP CODE.
Use the code at the top of the piston. x8z6x.
Thank you.
I found it googling. Here is the GitHub link: https://github.com/imnotbob/vacation-lighting-director/blob/master/smartapps/imnotbob/vacation-lighting-director.src/vacation-lighting-director.groovy
