I keep Sabbath and I want to know if there’s a way to disable the Multipurpose sensor for Sabbath.
I would suggest you make a mode called “sabbath” in the ide and set all your automations to not run in this mode.
I’m talking about disabling the open/closed sensor on the Multipurpose sensor.
you can remove the battery.
Will they stick to the door post after I remove the sensor?
You can’t “disable” a sensor from sending reports unless you remove the batteries. You can disable the automations via a mode.
I would imagine that you might be able to keep the contact closed by judicious positioning of a magnet. I can’t offer any practical details.
The short answer is nothing programmatic, but you can see a previous discussion that covers some options in the following thread. (This is a clickable link)
