Switch? For me only show roller… Thanks
I only have a Shelly 2.5 right now and a use it for two switches. Both showed up ad soon as I linked smartthings to Shelly cloud.
Did you test if webcore recognize the device? 2 switch and work?
There are delay using it with smartthings?
Thanks.
Did anyone manage to use a Shelly 2.5 as a roller shutter?
I use 2.5 as a roller shutter, but I can’t find it in smartthings. But I use a H&T sensor that works with smartthings
Yes. It works perfecty
Could you please share a photo of the controls in smartthings App?
The kitchen roller shutter is from Figaro. The other one from Shelly
Every 2-3 days Smartthings will lose control over Shelly devices and I have to reconnect to Shelly Clouds in adding devices. Is there a way to make the control not going offline?
Same here! Really bugs me, because I have some automations using Shelly!!
Had the same issue - i deleted the connection from smartthings to the shelly cloud entirely and connected again afterwards. All routines for the shellys were deleted but since then i dont have that issue anymore. Instead another issue came up - a delay of one to two seconds which i didnt have before…
Where can I find the DH for the Shelly 1 Relay?
There is no DTH for the Shelly 1. It is a c2c (cloud to cloud) integration.
Pair the Shelly 1 with the Shelly app then Go to add device in Smartthings and pick Shelly.
