How to change the dashboard setting of multi sensor?
I have multiple multi sensors /door sensor and all of them have motion, temp sensors in them. When you add these to your ST App dashboard, it shows motion/contact info by default. Is there a way to change this? Like I want one sensor to display temp, other for contact etc?
Yup, did as you said. Still cant see the temperate in the dashboard of the multi sensor.
Since I have published it, I dont know how to go to the code view. So posting a pic. Let me know if this dosnt work
Thanks! This helped me on another issue I was having!
  • Copyright 2016 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not
  • use this file except in compliance with the License. You may obtain a copy
  • of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software
  • distributed under the License is distributed on an “AS IS” BASIS, WITHOUT
  • WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
  • License for the specific language governing permissions and limitations
  • under the License.
    import physicalgraph.zigbee.clusters.iaszone.ZoneStatus
    import physicalgraph.zigbee.zcl.DataType
metadata {
definition(name: “SmartSense Multi Sensor Update”, namespace: “smartthings”, author: “SmartThings”) {
capability “Temperature Measurement”
capability "Three Axis"
capability "Battery"
capability "Configuration"
capability "Sensor"
capability "Contact Sensor"
capability "Acceleration Sensor"
capability "Refresh"
capability “Health Check”
	command "enrollResponse"
	fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05,FC02", outClusters: "0019", manufacturer: "CentraLite", model: "3320"
	fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05,FC02", outClusters: "0019", manufacturer: "CentraLite", model: "3321"
	fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05,FC02", outClusters: "0019", manufacturer: "CentraLite", model: "3321-S", deviceJoinName: "Multipurpose Sensor"
	fingerprint inClusters: "0000,0001,0003,000F,0020,0402,0500,FC02", outClusters: "0019", manufacturer: "SmartThings", model: "multiv4", deviceJoinName: "Multipurpose Sensor"
	attribute "status", "string"
simulator {
	status "open": "zone report :: type: 19 value: 0031"
	status "closed": "zone report :: type: 19 value: 0030"
	status "acceleration": "acceleration: 1"
	status "no acceleration": "acceleration: 0"
	for (int i = 10; i <= 50; i += 10) {
		status "temp ${i}C": "contactState: 0, accelerationState: 0, temp: $i C, battery: 100"
	// kinda hacky because it depends on how it is installed
	status "x,y,z: 0,0,0": "x: 0, y: 0, z: 0"
	status "x,y,z: 1000,0,0": "x: 1000, y: 0, z: 0"
	status "x,y,z: 0,1000,0": "x: 0, y: 1000, z: 0"
	status "x,y,z: 0,0,1000": "x: 0, y: 0, z: 1000"
preferences {
	section {
		image(name: 'educationalcontent', multiple: true, images: [
				"http://cdn.device-gse.smartthings.com/Multi/Multi1.jpg",
				"http://cdn.device-gse.smartthings.com/Multi/Multi2.jpg",
				"http://cdn.device-gse.smartthings.com/Multi/Multi3.jpg",
				"http://cdn.device-gse.smartthings.com/Multi/Multi4.jpg"
	section {
		input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter '-5'. If 3 degrees too cold, enter '+3'.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
		input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
	section {
		input("garageSensor", "enum", title: "Do you want to use this sensor on a garage door?", description: "Tap to set", options: ["Yes", "No"], defaultValue: "No", required: false, displayDuringSetup: false)
tiles(scale: 2) {
	multiAttributeTile(name: "status", type: "generic", width: 6, height: 4) {
		tileAttribute("device.status", key: "PRIMARY_CONTROL") {
			attributeState "open", label: 'Open', icon: "st.contact.contact.open", backgroundColor: "#e86d13"
			attributeState "closed", label: 'Closed', icon: "st.contact.contact.closed", backgroundColor: "#00a0dc"
			attributeState "garage-open", label: 'Open', icon: "st.doors.garage.garage-open", backgroundColor: "#e86d13"
			attributeState "garage-closed", label: 'Closed', icon: "st.doors.garage.garage-closed", backgroundColor: "#00a0dc"
	standardTile("contact", "device.contact", width: 2, height: 2) {
		state("open", label: 'Open', icon: "st.contact.contact.open", backgroundColor: "#e86d13")
		state("closed", label: 'Closed', icon: "st.contact.contact.closed", backgroundColor: "#00a0dc")
	standardTile("acceleration", "device.acceleration", width: 2, height: 2) {
		state("active", label: 'Active', icon: "st.motion.acceleration.active", backgroundColor: "#00a0dc")
		state("inactive", label: 'Inactive', icon: "st.motion.acceleration.inactive", backgroundColor: "#cccccc")
	valueTile("temperature", "device.temperature", width: 2, height: 2) {
		state("temperature", label: '${currentValue}°',
				backgroundColors: [
						[value: 31, color: "#153591"],
						[value: 44, color: "#1e9cbb"],
						[value: 59, color: "#90d2a7"],
						[value: 74, color: "#44b621"],
						[value: 84, color: "#f1d801"],
						[value: 95, color: "#d04e00"],
						[value: 96, color: "#bc2323"]
	valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
		state "battery", label: '${currentValue}% battery', unit: ""
	standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
		state "default", action: "refresh.refresh", icon: "st.secondary.refresh"
	main(["status", "acceleration", "temperature"])
	details(["status", "acceleration", "temperature", "battery", "refresh"])
def maps = []
maps << zigbee.getEvent(description)
if (!maps[0]) {
maps = []
if (description?.startsWith(‘zone status’)) {
maps += parseIasMessage(description)
} else {
Map descMap = zigbee.parseDescriptionAsMap(description)
if (descMap?.clusterInt == 0x0001 && descMap.commandInt != 0x07 && descMap?.value) {
maps << getBatteryResult(Integer.parseInt(descMap.value, 16))
} else if (descMap?.clusterInt == zigbee.TEMPERATURE_MEASUREMENT_CLUSTER && descMap.commandInt == 0x07) {
if (descMap.data[0] == “00”) {
log.debug "TEMP REPORTING CONFIG RESPONSE: $descMap"
sendEvent(name: “checkInterval”, value: 60 * 12, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID])
} else {
log.warn “TEMP REPORTING CONFIG FAILED- error code: ${descMap.data[0]}”
} else if (descMap?.clusterInt == zigbee.IAS_ZONE_CLUSTER && descMap.attrInt == zigbee.ATTRIBUTE_IAS_ZONE_STATUS && descMap?.value) {
maps += translateZoneStatus(new ZoneStatus(zigbee.convertToInt(descMap?.value)))
} else {
maps += handleAcceleration(descMap)
} else if (maps[0].name == “temperature”) {
def map = maps[0]
if (tempOffset) {
map.value = (int) map.value + (int) tempOffset
map.descriptionText = temperatureScale == ‘C’ ? ‘{{ device.displayName }} was {{ value }}°C’ : '{{ device.displayName }} was {{ value }}°F’
map.translatable = true
def result = maps.inject([]) {acc, it ->
	if (it) {
		acc << createEvent(it)
if (description?.startsWith('enroll request')) {
	List cmds = zigbee.enrollResponse()
	log.debug "enroll response: ${cmds}"
	result = cmds?.collect { new physicalgraph.device.HubAction(it) }
return result
private List handleAcceleration(descMap) {
def result = []
if (descMap.clusterInt == 0xFC02 && descMap.attrInt == 0x0010) {
def value = descMap.value == “01” ? “active” : "inactive"
log.debug "Acceleration $value"
result << [
value : value,
descriptionText: “{{ device.displayName }} was $value”,
isStateChange : isStateChange(device, “acceleration”, value),
translatable : true
	if (descMap.additionalAttrs) {
		result += parseAxis(descMap.additionalAttrs)
} else if (descMap.clusterInt == 0xFC02 && descMap.attrInt == 0x0012) {
	def addAttrs = descMap.additionalAttrs ?: []
	addAttrs << ["attrInt": descMap.attrInt, "value": descMap.value]
	result += parseAxis(addAttrs)
return result
private List parseAxis(List attrData) {
def results = []
def x = hexToSignedInt(attrData.find { it.attrInt == 0x0012 }?.value)
def y = hexToSignedInt(attrData.find { it.attrInt == 0x0013 }?.value)
def z = hexToSignedInt(attrData.find { it.attrInt == 0x0014 }?.value)
if ([x, y ,z].any { it == null }) {
	return []
def xyzResults = [:]
if (device.getDataValue("manufacturer") == "SmartThings") {
	// This mapping matches the current behavior of the Device Handler for the Centralite sensors
	xyzResults.x = z
	xyzResults.y = y
	xyzResults.z = -x
} else {
	// The axises reported by the Device Handler differ from the axises reported by the sensor
	// This may change in the future
	xyzResults.x = z
	xyzResults.y = x
	xyzResults.z = y
log.debug "parseAxis -- ${xyzResults}"
if (garageSensor == "Yes")
	results += garageEvent(xyzResults.z)
def value = "${xyzResults.x},${xyzResults.y},${xyzResults.z}"
results << [
		value          : value,
		linkText       : getLinkText(device),
		descriptionText: "${getLinkText(device)} was ${value}",
		handlerName    : name,
		isStateChange  : isStateChange(device, "threeAxis", value),
		displayed      : false
results
private List parseIasMessage(String description) {
ZoneStatus zs = zigbee.parseZoneStatus(description)
translateZoneStatus(zs)
private List translateZoneStatus(ZoneStatus zs) {
List results = []
if (garageSensor != "Yes") {
	def value = zs.isAlarm1Set() ? 'open' : 'closed'
	log.debug "Contact: ${device.displayName} value = ${value}"
	def descriptionText = value == 'open' ? '{{ device.displayName }} was opened' : '{{ device.displayName }} was closed'
	results << [name: 'contact', value: value, descriptionText: descriptionText, displayed: false, translatable: true]
	results << [name: 'status', value: value, descriptionText: descriptionText, translatable: true]
return results
private Map getBatteryResult(rawValue) {
log.debug “Battery rawValue = ${rawValue}”
def result = [:]
def volts = rawValue / 10
if (!(rawValue == 0 || rawValue == 255)) {
	result.name = 'battery'
	result.translatable = true
	result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
		volts = rawValue // For the batteryMap to work the key needs to be an int
		def batteryMap = [28: 100, 27: 100, 26: 100, 25: 90, 24: 90, 23: 70,
						  22: 70, 21: 50, 20: 50, 19: 30, 18: 30, 17: 15, 16: 1, 15: 0]
		def minVolts = 15
		def maxVolts = 28
		if (volts < minVolts)
			volts = minVolts
		else if (volts > maxVolts)
			volts = maxVolts
		def pct = batteryMap[volts]
		result.value = pct
	} else {
		def useOldBatt = shouldUseOldBatteryReporting()
		def minVolts = 2.1
		def maxVolts = useOldBatt ? 3.0 : 2.7
		// Get the current battery percentage as a multiplier 0 - 1
		def curValVolts = Integer.parseInt(device.currentState("battery")?.value ?: "100") / 100.0
		// Find the corresponding voltage from our range
		curValVolts = curValVolts * (maxVolts - minVolts) + minVolts
		// Round to the nearest 10th of a volt
		curValVolts = Math.round(10 * curValVolts) / 10.0
		// Only update the battery reading if we don't have a last reading,
		// OR we have received the same reading twice in a row
		// OR we don't currently have a battery reading
		// OR the value we just received is at least 2 steps off from the last reported value
		// OR the device's firmware is older than 1.15.7
		if(useOldBatt || state?.lastVolts == null || state?.lastVolts == volts || device.currentState("battery")?.value == null || Math.abs(curValVolts - volts) > 0.1) {
			def pct = (volts - minVolts) / (maxVolts - minVolts)
			def roundedPct = Math.round(pct * 100)
			if (roundedPct <= 0)
				roundedPct = 1
			result.value = Math.min(100, roundedPct)
		} else {
			// Don't update as we want to smooth the battery values, but do report the last battery state for record keeping purposes
			result.value = device.currentState("battery").value
		state.lastVolts = volts
return result
List garageEvent(zValue) {
List results = []
def absValue = zValue.abs()
def contactValue = null
def garageValue = null
if (absValue > 900) {
contactValue = 'closed’
garageValue = ‘garage-closed’
} else if (absValue < 100) {
contactValue = 'open’
garageValue = ‘garage-open’
if (contactValue != null) {
def descriptionText = contactValue == ‘open’ ? ‘{{ device.displayName }} was opened’ : '{{ device.displayName }} was closed’
results << [name: ‘contact’, value: contactValue, descriptionText: descriptionText, displayed: false, translatable: true]
results << [name: ‘status’, value: garageValue, descriptionText: descriptionText, translatable: true]
results
  • PING is used by Device-Watch in attempt to reach the Device
    def ping() {
    return zigbee.readAttribute(0x001, 0x0020) // Read the Battery Level
def refresh() {
log.debug "Refreshing Values "
def refreshCmds = zigbee.readAttribute(zigbee.TEMPERATURE_MEASUREMENT_CLUSTER, 0x0000) +
		zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020) +
		zigbee.readAttribute(0xFC02, 0x0010, [mfgCode: manufacturerCode]) +
		zigbee.readAttribute(zigbee.IAS_ZONE_CLUSTER, zigbee.ATTRIBUTE_IAS_ZONE_STATUS) + zigbee.enrollResponse()
return refreshCmds
def configure() {
// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
// enrolls with default periodic reporting until newer 5 min interval is confirmed
sendEvent(name: “checkInterval”, value: 2 * 60 * 60 + 1 * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID])
log.debug "Configuring Reporting"
def configCmds = []
	log.debug "Refreshing Values for manufacturer: SmartThings "
	/* These values of Motion Threshold Multiplier(0x01) and Motion Threshold (0x0276)
    seem to be giving pretty accurate results for the XYZ co-ordinates for this manufacturer.
    Separating these out in a separate if-else because I do not want to touch Centralite part
    as of now.
	configCmds += zigbee.writeAttribute(0xFC02, 0x0000, 0x20, 0x01, [mfgCode: manufacturerCode])
	configCmds += zigbee.writeAttribute(0xFC02, 0x0002, 0x21, 0x0276, [mfgCode: manufacturerCode])
} else {
	// Write a motion threshold of 2 * .063g = .126g
	// Currently due to a Centralite firmware issue, this will cause a read attribute response that
	// indicates acceleration even when there isn't.
	configCmds += zigbee.writeAttribute(0xFC02, 0x0000, 0x20, 0x02, [mfgCode: manufacturerCode])
// temperature minReportTime 30 seconds, maxReportTime 5 min. Reporting interval if no activity
// battery minReport 30 seconds, maxReportTime 6 hrs by default
configCmds += zigbee.batteryConfig() +
		zigbee.temperatureConfig(30, 300) +
		zigbee.configureReporting(0xFC02, 0x0010, DataType.BITMAP8, 10, 3600, 0x01, [mfgCode: manufacturerCode]) +
		zigbee.configureReporting(0xFC02, 0x0012, DataType.INT16, 1, 3600, 0x0001, [mfgCode: manufacturerCode]) +
		zigbee.configureReporting(0xFC02, 0x0013, DataType.INT16, 1, 3600, 0x0001, [mfgCode: manufacturerCode]) +
		zigbee.configureReporting(0xFC02, 0x0014, DataType.INT16, 1, 3600, 0x0001, [mfgCode: manufacturerCode])
return refresh() + configCmds
def updated() {
log.debug "updated called"
log.info "garage value : $garageSensor"
if (garageSensor == “Yes”) {
def descriptionText = "Updating device to garage sensor"
if (device.latestValue(“status”) == “open”) {
sendEvent(name: ‘status’, value: ‘garage-open’, descriptionText: descriptionText, translatable: true)
} else if (device.latestValue(“status”) == “closed”) {
sendEvent(name: ‘status’, value: ‘garage-closed’, descriptionText: descriptionText, translatable: true)
} else {
def descriptionText = "Updating device to open/close sensor"
if (device.latestValue(“status”) == “garage-open”) {
sendEvent(name: ‘status’, value: ‘open’, descriptionText: descriptionText, translatable: true)
} else if (device.latestValue(“status”) == “garage-closed”) {
sendEvent(name: ‘status’, value: ‘closed’, descriptionText: descriptionText, translatable: true)
private hexToSignedInt(hexVal) {
if (!hexVal) {
return null
def unsignedVal = hexToInt(hexVal)
unsignedVal > 32767 ? unsignedVal - 65536 : unsignedVal
private getManufacturerCode() {
if (device.getDataValue(“manufacturer”) == “SmartThings”) {
return “0x110A”
} else {
return “0x104E”
private shouldUseOldBatteryReporting() {
def isFwVersionLess = true // By default use the old battery reporting
def deviceFwVer = "${device.getFirmwareVersion()}"
def deviceVersion = deviceFwVer.tokenize(’.’) // We expect the format ###.###.### where ### is some integer
if (deviceVersion.size() == 3) {
	def targetVersion = [1, 15, 7] // Centralite Firmware 1.15.7 contains battery smoothing fixes, so versions before that should NOT be smoothed
	def devMajor = deviceVersion[0] as int
	def devMinor = deviceVersion[1] as int
	def devBuild = deviceVersion[2] as int
	isFwVersionLess = ((devMajor < targetVersion[0]) ||
		(devMajor == targetVersion[0] && devMinor < targetVersion[1]) ||
		(devMajor == targetVersion[0] && devMinor == targetVersion[1] && devBuild < targetVersion[2]))
return isFwVersionLess // If f/w version is less than 1.15.7 then do NOT smooth battery reports and use the old reporting
private hexToInt(value) {
new BigInteger(value, 16)
Thank you! Just curious. Can this also be dynamic? Like if there is no motion, then it should show temp. When there is motion/open contact then that gets displayed in dash board
So this doesn’t work for the new app… any other suggestions @anon36505037
No other options for the new app yet.
