im just getting started with the smartthings home montitoring kit. Ver 2
ive got everthing connected but i cant make sense of how to tap into the xyz feature of the sensor
how do i use it?
for example, lets say i want ot mount it on my garage door to sense horizontal vs veritcal
i tried moving the sensor around with my hand while monitoring the app and it doesnt seem to continuosly change the x y z readings
You have to go into settings and select garage door then pick the proper axis.
thanks but shouldnt i see the xzy values change in the app (when im looking at the device screen) when i move the sensor around?
are there other use cases for this xyz sensor besides garage door that are documented somewhere?
jkp
4
use @Mariano_Colmenarejo version of the contact sensor to get the xyz axis
As JKP said you want to use Mariano’s “ZigBee Contact Mc” Edge Driver.
Ill take a look at that thx.
Im beginning to think smartthings is not really a finished product but more like a hobby enthusiasts/project… os that about right?
Bry
(Bryan)
7
There isn’t a home automation system out there that is “finished”. Pretty much an oxymoron.
