Badger51
(Douglas Drake)
March 19, 2023, 4:33pm
1
I have replaced my original OG Smartthings Garage Door sensor that I have used for many years.
(started with Smartthings through Kickstarter)
I understand there are no drivers for the original sensor. I have replaced it with AEOTEC Multi Purpose Sensor (IM6001-MPP)
The device paired quickly with my Hub. Per prior discussions in the community, I am using Mariano Shared Beta Driver, with Zigbee Contact Test.
I have selected yes for Garage Door and selected Z axis to associate with the door being open or closed.
The sensor tracks vibration and temperature, but always shows the door as open.
Any suggestions?
TIA
Badger51:
Any suggestions
If it shows always open, you have chosen Z axis and measures approximately <100 mG with the door both open and closed.
you can physically rotate the sensor to have the Z axis measuring > 900 mG for closed and < 100 mG for open
You can also change the preferences to the X or Y axis and try
Badger51:
IM6001-MPP
I “was” using the STOCK SmartThings Zigbee Contact Driver, which has a Garage Door Option in the Settings, which was working fine.
In exploring why the Channel info was blank (3rd screenshot), I installed the SmartThings Managed - Beta Channel Zigbee Contact Driver (4th screenshot), now it won’t let me switch back to stock LOL!
Still seems to function the same way.
Badger51
(Douglas Drake)
March 19, 2023, 6:25pm
4
Thanks for the prompt reply.
Following suggestions in prior threads, I did switch to the Y axis setting, in place of the Z axis.
So far, appears to be working fine.
Thanks again.
