I have created an initial sensor motion override piston in WebCoRE. How do I get it to get in SmartThings app?
As long as the piston hasn’t been paused, the moment you save it, it should become active…
TheBearMay, thanks for the response. So then what exactly is the Test in the dashboard.webcore Script do?
It lets you force a run - I use it a lot as I’m developing a piston to check flow and result. Trace will show you the path of execution through the piston(green show paths taken, red skipped due to a conditional) with the time spent in each segment.
Awesome, thanks again!
