How do I setup/download rule machine?
#1
The only topic I see has 630+ posts! A condensed version would be great!
(Tintin) #2
Check the first post here - it has all that you need to get started Rule machine - as per the app developer, this app is no longer available for new installs, distribution, or support
(Bob) #3
Everything you need to know is in the first post:
If you need assistance setting up your rule logic, ask here.
(Meep Meep.....) #4
Synopsis. Copy github code. Login to ide. Goto smart app. Paste custom code. Save publish. Goto mobile app./ marketplace my smart app/ install my app. Should install rule machine. Wish there was videos how to but once you do it once it’s rinse and repeat methodology.
Tldr see Mr lucky post above.
#5
What is the best way to copy the github post on an iPhone? It’s pretty tough to do.
(Meep Meep.....) #6
Advice. The work has to be done on a workstation not a mobile device. It become irritating like digging a hole with a spoon instead of using a shovel. It can get it done but it’s not the right tool
#7
Thanks, I figured that. I setup a nest thermostat on a MacBook Air. I just figured someone figured out a workaround to be able to do it on an iPhone.
#8
I’ve got it installed now I’ve got to figure out how to use it!
(Brandon Harold) #9
Is rule machine still available anywhere? Or is it depreciated?
#10
I don’t know. I have installed it but I have never used it.
(Chris Fichter) #11
Not available. For now hopefully. We’re all hoping he brings it back. I don’t know how much you know but he took it off until the system is more stable.
