How can I connect an IRobot I7 to Smartthings?
How can I connect an IRobot I7 to Smartthings? with alexa it’s ok but i don’t understand how to go about seeing it in smartthings.
Thanks for your help I’m new to smartthings.
Greetings
There’s no direct integration available at this time. :disappointed_relieved: (If you open the smartthings app, tap on the + in the upper right, choose devices, and then choose by brand, you can see which brands offer direct integration.)
You can use IFTTT as an intermediary.
You can also use an Alexa routine as an intermediary, but that gives you fewer choices. You can issue the command to the vacuum via Alexa, but you can’t use iRobot actions as a trigger like you can with Ifttt.
