I have a Honeywell RTH6500 wifi thermostat and I am able to fully control it from the Honeywell TCC phone app.
How do I set up ST integration for this device?
According to this statement on the ST compatible devices list I should be able to do this, but I don’t see how:
“All Honeywell 6000, 8000, and 9000 series thermostats supported in the Honeywell Total Comfort Connect app are compatible with SmartThings.”
go to marketplace / things / thermostats. if your exact model isn’t listed find on that is close that what i did for mine. but the 6000 series one should work for you
The problem I have is what when i try to add the Honeywell Total Comfort app in Smarthings (new app) it just crashes. Is there any way to add it in the classic app?
Got to say that you are one of the lucky ones if you are able to set the Honeywell Thermostat units up in ST.
Honeywell / Resideo decided to split their product offering across 2x website for control.
1 site is for the US and other related regions of the world accessed by the website mytotalconnectcomfort.com
The other site international.mytotalconnectcomfort.com is for the other many many countries that use the Honeywell WiFi thermostats.
The problem is that you cant have an account on both websites, and it looks like the ST device driver is only programmed to access webhooks / API’s on the Non international website.
So for most of the developed world embracing ST and Honeywell, you are just plain out of luck.
Great product the Honeywell WiFi 9000 thermostat, just cant integrate it with ST if you are an international user.
If mytotalconnectcomfort.com (North America + other related locations, but not most of the International locations website.) then I would suspect your Honeywell device would work out of the box.
