Honeywell TH8320ZW zwave thermostat won't pair...kind of
I have an existing zwave setup with a vera lite that I am moving to Smartthings hub. I successfully unpaired from vera but if I go though the inclusion process with smartthings it never discovers or connects. I just get the “looking for Honeywell TH8320ZW” it could take a moment spinning thingy. The thermostat then displays a node and seems to be connected. The odd thing is via smartthings I can exclude the thermostat and it is successful. I am now in the rinse and repeat phase. Any help would be appreciated.
Solved! After pairing this thermostat you then need to tell it to broadcast it’s node while the smartthings is trying to connect or find the device.
