I’m needing help with my older Honeywell zwave thermostats, model TH8320ZW. I’m guessing this is all related to this major move to drivers from the old IDE system or whatever is going on. I’ve done some research and it sounds like my devices were auto converted and using a generic thermostat driver. My thermostats work, but they always give an error message when I select them, I’m guessing from them not having humidity sensors, and when I change temps it does it in increments with 10th of degrees.
I came across some info on other older Honeywell thermostats and it sounds like there’s a driver out there for ones without humidity sensors. How can I find that and get it installed? Any help is appreciated.
