Does anyone know if … Honeywell RTH8560D1002/E works with Smartthings?
When searching for… “thermostats compatible with smartthings” this is one that is listed.
However, there is nothing in the Specs.
Thanks for your Comments !
Where did you find that it says it was compatible with ST?
I couldn’t find anything either that said this Tstat was WiFi, zigbee or ZWave. I also took a quick peak at the Smartthings/Honeywell compatible Tstat list and this one wasn’t on the lists I found.
