Prior to the new IOS app I had total control of the temperature of my Honeywell 9500 thermostat. Now I have no + or - so essentially just shows temp, state, mode ,and fan mode. Temperature adjustment and humidity missing. I have tried all the different device drivers available. Is there another available?
Can’t answer your last question exactly, but I’m seeing the same thing with a Honeywell Prestige IAQ. Interestingly though, even though you can’t control settings through the app, those things are still exposed so you can control them via webCore, Rule Engine, SharpTools, etc.
Try removing and readding your thermostat. This issue was fixed sometime ago but some folks needed to re-add the thermostats for the controls to show up.
