Home Activity Simulator (Make it look like i'm home App)
I am looking to create a mode that does the following when the Mode is set to “Away”.
At Sunset Every X Minutes light a light for X Minutes. At sunrise stop.
How do I got about this?
Vacation lighting director smart app.
Or you could set up something like this in CoRE.
This gives a random time between turning on and off.
I have tried that. However it “cycles” lights. Doesn’t that mean that every
X minites in switches one light off and turns another on?
I would like to have for example every 90 minutes turn the kitchen lights
on for 5 minutes.
Hmmm what is that? I have been wondering to how "create custom programs"
for ST
This should get you started.
I am using the UK version. What are my options?
GitHub IDE integration is only available in the US.
Github is available in the UK now.
I use it.
You can just copy and paste the code into a new smartapp if you wish.
Might be easier to start with so you can get it working.
Another thing to note is that after you have gone into marketplace-> my smartapps for the initial set up, for all subsequent times you open CoRE, go through automation -> smmartapps tab.
If you don’t you will have issues building new pistons.
Looking to do it thr right way from the start cause I assume that updates will be automatic afterwards right? I am not seeing github integration for the UK version of ST
Thank you everyone for all the prompt information. I will give it a try
tomorrow.
So far so good. How do I make it repeat after the random 30-120 minute wait?
Not really sure but if you look at my piston in post 3 you will see how i do it.
Thanks for pointing that mistake out. So is it correct now?
Looks good to me.
Thank you both. Very kind of you to offer help so promptly. So far I am very happy with my ST System and with this Core thing it seems I have opened up a whole new world.
Just as an aside, personally I always have Task Cancellation Policy (TCP) set to cancel on piston state change.
I find this is the best policy when timers are involved.
Sometimes with the way I set up rules the timers keep resetting and never mature.
TCP active stops this.
Can you elaborate on this?
If you go to your THEN scroll down the page andyou will find Task Cancellation Policy
Check Cancel On Piston State Change.
Like I said, probably not an issue but I have had some pistons that keep resetting the timers so that they never mature.
I just do it as a matter of course now.
Noted! Thanks.
One last thing for now. If i want to update to the latest core do I simply edit to the update code from github? If so will I lose my “Pistons”?
