HELP! Z-Wave devices offline!
Hi all - have had a very stable Smartthings v2 platform for at least 7 years. A couple of weeks ago, a large number of my Z-Wave devices have been going offline. Some will come back on, but most remain offline and the list keeps growing. I have tried multiple hub reboots, Z-Wave repairs, and unplugging/removing batteries. I am using an Android phone, but the devices are showing up offline on both the Android app and Web version. Any ideas to help troubleshoot and fix are MUCH appreciated - thank you!
Doesn’t really sound like the same issue as the other thread…
You’ve probably already done this, but when you check the hub radio status at
my.smartthings.com/advanced
What does it show about the Z wave radio in the hub?
Other than that, I agree absolutely that you should contact SmartThings support and see if they can see anything from their side. :thinking:
I noted you removed batteries from battery-operated Z-Wave Devices. Do you have any AC-Powered Z-Wave Devices (such as wired Light Switch or anything Plugged into a Wall Receptacle) ?
If so, pull the power on those devices by either unplugging or shutting off the circuit breaker (after first shutting down any other electronic devices you have plugged into that circuit).
I experienced something very similar to what you described. No matter how many Hub Reboots, or Z-Wave Repairs I performed, nothing helped. UNTIL I pulled power on Wired Z-Wave Devices.
Good luck and report back !
I sincerely appreciate everyone’s help and suggestions. For whatever reason, I had not tried flipping the circuit breakers - that seems to be doing the trick!! A couple of them still offline, but I’ll keep working at it!
@Magiccarpetride9
Have you identified “all” of your AC-Powered Z-Wave Devices? Is there one hiding/lurking beyond your recollection ? :grin:
There’s a detailed step-by-step here, cautioning proper shut down of all OTHER electronic equipment before pulling a circuit breaker.
Keep us posted!
