I have an existing ZW100-C working as expecting after changing from moisture sensor to the correct device type, have added another two which were this time detected as a Multisensor 6 (I assume because the first one already existed) but these ones won’t capture motion. I have tried a couple of other DTH to resolve this but none of them are doing the same.
Before I rule out an issue with the devices themselves do you have any suggestions?
I’ve tried removing and re-adding a number of times. One difference between these two and the existing one is that the LED lights are smaller but I assume a change to the design rather than anything else as they are both listing the same firmware and have same label on the back with model number etc…
