I have a Lutron Caseta dimmer in my bedroom and it’s hooked up to an overhead light that currently has 3 100W incandescent bulbs.
I like the Philips Warmglow lights and tried to use the 60W equivalent bulbs in the fixture, but they would flash constantly when the dimmer was turned on to any level.
I then tried to Philips Warmglow 100W equivalent bulbs (A21) and they didn’t fit in the fixture.
So, ideally, looking for an option that dims to a warmer color that works well with the Caseta dimmer. Barring that, just looking for a recommendation for a soft white A19 LED bulb that dims to a low level when paired with the Caseta dimmer.
Thanks. I should have mentioned that I looked at their tool, but that doesn’t give insight into what I’m specifically looking for:
A compatible bulb that may not be on their list that is “warm dimmable,” i.e. dims to a warmer color temperature
Or, a compatible bulb that dims to a low level with the Caseta, which is impossible to tell from the compatibility chart, hence the reason I am asking the question here.
Why would the casseta be different from any other 110v dimmer?
I had success with off brand LED bulbs on aliexpress getting from 3-4 different vendors (these are supercheap) and one hopefully would work, dimmable, warm, without flickering. It’s hit or miss but you spend very little.
Caseta dimmers don’t have a neutral wire. The minimum voltage and initial load of some LEDs can make them not work properly with Caseta dimmers even though they work properly with other dimmers.
