Help to use this Tuya device with garage door
Been trying to get a edge driver to work with this as a garage door opener but can’t find one to work it’s driving me nuts if someone could help
In the case of tuya devices, just looking at the case doesn’t help. You have to follow the directions in the Tuya FAQ and get the fingerprint and the clusters.
FAQ: Using Tuya Zigbee Devices Directly With a SmartThings/Aeotec Hub (2024)
That still doesn’t mean it’s going to work as a garage door opener, though. People will need to know the brand and model of the garage door controller that you are trying to use it with.
I did check that out and tried a few drivers just couldn’t get one to work nor was there one just for a tuya zigbee garage door opener
The name that comes up it just says generic-ef00-v1
Model ts0601 and manufacturer code tze204-nklqik62
There is no actual brand name on it
And what’s the brand and model name of the actual motor for the garage door opener. The tuya device is just like a switch for it. But you must have another device that has the motor to open the door.
It would be a craftsman model 139.53930DM
I have non clue about these edge drivers
This worked for me.
