Help new to zwave and smarthings help setting up relay
hello iam new to this technology ill keep it short and sweet. i wanted in integrate pretty everything in my house using Samsung smartthings got the new tablet refrigerator that added fine the ecobee 4 that added fine bought a Samsung smart front door lock but its only as smart as being able to use a card for access. but after tearing it apart there is a video door bell release port on it … so i shorted it out and bam it unlocked and shorted it out again and it locked so i drilled through my door used a power transfer hinge to a remotec ZFM-80 zwave relay … so iam new to this whole system the other devices i added it was search connect and control. this relay i finally got it to connect but on the app it just says zwave relay … i have labeled it front door. but when i tap it nothing happens no on or off switch appears nothing when i log on the computer i can see it active and i started messing around i think i have to create the actions and assign it to the relay iam not sure i used a template and in the simulator i can turn it on and off and work it in the simulator but i do not know what to do next or how to set this up thank you.
ok thank you i will try it in the am. sorry i just get lost into thought and if i do not get it all out of my mind i lose track of where i was. lol …
well i messed around with it this morning. so this is what screwed me up …
when i bought the Samsung smarthings hub it told me to use Samsung connect. so with that was great for simple stuff. so i was using the wrong app. i downloaded Samsung smarthings app and now i have all the tools i was looking for. The relay had a already relay profile in it and works as i wanted to. door works amazing i will take pic and post to show how i added the relay and threw the door to the samsung SHS-3321 smart lock. the lock is amazing but wish it had the zwave or wifi built in. thank god it had the door release port built in.
