I have deleted some zigbee remotes of various brands with plans to add back using Edge drivers for local control. The issue is that I deleted from the app but the devices are still showing in the IDE. I tried re-adding using the stock DTH and but they are not adding back correctly if at all.
Eria dimming remote
Ecosmart remote
In US on V3 hub
Once I confirmed the Edge driver(s) I wanted to use were on the hub, I deleted the devices with the app and immediately added them back and they picked up the Edge driver.
I can’t get them removed from the hub. After deleting from app the device stills shows active in the IDE and automations continue to work despite device not showing in the app.
