I need help in installing the Nano Dimmer. Sorry, I am not an electrician but is handy enough when given proper instructions.
I have a 3-way light switch where both switches have 3 wires. I didn’t saw any other lines connected to any of the two switches so I am “guessing” that the load (light) must be in the middle (please correct me if there is another possible configuration).
How would I connect the nano dimmer with this configuration?
I have attached photos of both switches for reference.
here is a drawing of how I wired mine. My power came in at the light so my micro is in the light box in the ceiling. I took quite a few meter reading and continuity checks then labeled all my
wires. I then rewired everything to match what I have in the drawing.
Be aware the micro connections for the switch wires are very small. I had to use a separate smaller gauge wire and wire nuts to make those connections.
Maybe you can do some checks and see if your layout matches what I had or you can use what I found and go from there.
When I wired my micro. I had to move almost every wire to make it match what they said in their diagrams. It wasn’t a simple plug and play. It took me a few tries and lots or wire tracing , labeling and verifying to get it right.
I somehow missed that thread. By the way, is your micro a dimmer or a switch? Also, it looks like from your diagram that it will work on two wires. Maybe I need to buy that and return the nano.
