Hi, I’m trying to setup the hello-world sampledriver. I did every step of this tutorial successfully
Get Started with SmartThings Edge | Developer Documentation | SmartThings.
When I try the last step:
- Add your device in the SmartThings app by navigating to Add a Device > Scan Nearby
It just spins and doesn’ find the device. I also get this error when I try to see the logs:
Error: write EPROTO 18620:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:c:\pkg-fetch\precompile\node\deps\openssl\openssl\ssl\record\ssl3_record.c:332:
Note: I see the driver listed in the application in the Driver menu. I just can’t figure out how to create a device with it.
What am I missing here?
Thanks.
nayelyz
(SmartThings Developer Support)
2
Hi, there!
Are you using a Samsung Connect or ST WiFi Hub? If so, please check this announcement:
Thank you for your help. Yes I use a ST wifi hub. What is the best way to get notified when that gets fixed? The link you sent seems chatty.
nayelyz
4
Mmm… it’s possible the team makes another post to announce that, so you can check the updates here:
Also, I’ll come back to all the posts where this was asked and let you know. I already included you in the list.
Great, thank you very much.
Hi, any news concerning this issue?
Thanks and happy new year!
nayelyz
7
Thank you, happy new year to you too!
No, sorry, there are no updates yet regarding using Edge drivers on Wi-Fi Hubs.
