Heimantech Smoke Detector (zigbee) [ALPHA]
For those interested, I just did a draft version of the Heimantech Zigbee smoke detector.
It’s the first time I’m publishing something here… I hope it will be some value for anybody. By the way, I accept pull requests :-).
https://github.com/carldebilly/SmartThings-Stuff/tree/master/devicetypes/carldebilly/heimantech-zigbee-smoke-detector.src
Few features are still missing:
  • still need to report battery level
  • still need a low battery reporting (cluster 0x0500 b16ZoneStatus/bit 0)
  • should add the “Alarm” capability to remotely trigger the alarm (using cluster 0x0009)
  • should add the “remote shut off” capability (using cluster 0x0006)
  • should add the “tamper” reporting (cluster 0x0500 b16ZoneStatus/bit 2)
Carl.
To buy those cheap smoke detectors:
Company site: http://www.heimantech.com/product/89.html
Great work! Have you got any ideas how to solve the issues?
@carl.debilly Where did you find those cluster codes? I’ve been meaning to test the alarm activation, but only have time after kid goes to sleep.
@carl.debilly Thanks for taking time to code this device type. I had a heimantech smoke detector for a while and use it with a device type shared by another forum member. Its quite basic but works. To test, I can press the button on the alarm and it registers as smoke detected in smartthings.
I tried the same with your device type and didn’t work. Is this something not configured in your version? Please see the device handler I use below.
https://paste.ofcode.org/3afsqWQYW3X5u7SSsU3Pfrs
Do let me know if you have any updates to your device handler. I definitely would like to try it.
