Hi @zzr600
I’m glad it works!
Please, could you delete the logs?, they are no longer needed and it is cleaner for whoever reads it, thanks
Hi @zzr600
I’m glad it works!
Could you please also add the fingerprints for the Heiman CO_V16 detector to the Zigbee Smoke/CO Detector Mc driver please?
I take note to do it in the month of August, until then I do not have access to the CLI or a pc
Thank you and no problem to wait ![]()
deviceLabel: HEIMAN Smoke Detector
manufacturer: Heiman
model: SmokeSensor-N
deviceProfileName: smoke-battery
In driver exist this device
- id: "HEIMAN/SmokeSensor-N-3.0"
manufacturer: HEIMAN
model: SmokeSensor-N-3.0
Is model: SmokeSensor-N correct?
Thank you very much
Hi @Han.J @DerAnton and @Ronald_De_Boed the Heiman CO_V16´It may not work well, you tell me
Name Zigbee Smoke/CO Detector Mc
Version 2023-07-31T20:14:29.350757003
- id: "Heiman/SmokeSensor-N"
- id: "Heiman/CO_V16"
deviceLabel: HEIMAN CO Detector
model: CO_V16
deviceProfileName: co-battery
- id: "Trust/COSenssor-EM"
deviceLabel: Trust CO Detector
manufacturer: Trust
model: COSenssor-EM
@Mariano_Colmenarejo Thank you it is working fine! Only thing is the battery status, it says 2% with a new one but that takes maybe some time to update.
it does not work.
Could it be that the capitalization is wrong?
=> HEIMAN/SmokeSensor-N
=> HEIMAN
Sorry, fixed in this driver version
Version 2023-08-01T18:50:38.112795396
Hi! Any chance of getting this Nedis Zigbee CO alarm to work with smartthings? It looks like Heiman alarm. I tried it with Mariano’s zigbee driver for Heiman without success. Should it work? It only shows as a Zigbee Thing.
Could you install Zigbee Thing Mc driver.
Using Zigbee Thing Mc driver is possible to read exact model and manufacturer.
manufacturer:
model:
Server Cluster:
Client Cluster:
Hello,
An installed sensor(model:SmokeSensor-N) has a problem. Same as zzr600 (model:SMOK_V16).
After deleting the driver, I installed it directly.
a couple hours the device become offline.
After again a couple hours go back online.
(Battery information reported every 6 hours)
And this thing always repeat.
When is offline if the sensor is triggered, then become online and alert in app.
Can the solution applied to the SMOK_V16 model be applied to SmokeSensor-N?
Hi,
Try installing this driver version, uninstall device and pair with it for V16 device configuration
Version 2023-08-03T15:54:35.733568264
Here is the device information. Any chance to make a working driver for it?
Device Information:
Manufacturer: _TYZB01_07m83470
Model: TS0212
FingerPrinted_EndPoint.ld: 0x01
App Version: Unknown
ZCL Version: Unknown
Network ID: Ox63F8
Zigbee EUI: 84FD27FFFEA68713
Device ID: effaf65a-97eb-4762-8dff-
4356c56a991f
Server Cluster:
Ep: 0x01=< 0000,0001,0003,0500 )
Client Clusters:
Ep: 0x01=/0003,0019>
Signal Metrics:
What type of device is it? , smoke or CO detector
