Heat-it z-push button 2 & smartthings
Hi!
I bought a z-wave device from Heatiit (nice look that fits the schneider exxact frame), with the hope that it could work, however I have not been able to find a device handler that works.
Has anyone tried this device with more success?
Model number?
This model:
It looks very similar to the “Sunricher” model:
https://www.sunricher.com/single-color-wall-mounted-z-wave-push-button-secondary-controller-light-switch-sr-zv9001k2-dim.html#product_tabs_specifications
Is it the right radio frequency for your region/hub?
Hi, yes, it is the European frequency
You might try this one.
Tried it but unfortunately no success. It does not show any channels
A bit late, but I have created a device handler for this. Not testet for fingerprint, but it is tested and works. Tell me if you are interested in a copy.
Great!
Could you post the link to the device handler?
I would like a link too!
Also interested!
Can you specify more exacty what was not working.
The physical button or the button in the DH.
From webCoRE or any other Smartapp or routine.
I use the one with 8 buttons and it works both with webCoRE and associations.
Never tried an ything else.
Hi there
I’ve attempted to use the DH for 8 button (4x2) version.
I was able to publish the DH and include the device in the Z-Wave network. Fine so far.
However, using the (android) Classic app and hub v2 (2015), I’m able to observe (in the app) scene number-signals from the device corresponding to the physical buttons, but the app in itself does not show 8-buttons nor does it respond to any input.
Edit: Device cannot trig routines or SmartApps.
I’ve tried changing to various DH-‘types’ other than the deafault ‘Z-Wave device’ using the IDE but obviously that wont work.
!Screenshot_20190518-155836|241x500](upload://tOKRLvBuem1ixpuVgDVzwcaeCoE.jpeg)
Jeg kjÞpte en slik i dag. Kan du PLEASE gi meg Device-handler - link? I sÄ fall er du HELT genial :slight_smile:
mvh
Kristian
Hei Kristian
Det er ikke mulig Ä sende kode i meldingene her, sÄ jeg trenger en epost.
Send en epost til ivarsand@gmail.com
Jeg luker fortsatt ut feil, og trenger raw description pÄ 2 knapps varianten
DU finner den inne IDE nÄr du ser pÄ devicet.
Raw Description
zw:Ss type:1801 mfr:0330 prod:0300 model:A305 ver:1.26 zwv:5.03 lib:03 cc:5E,55,98,9F,6C sec:86,85,8E,70,5B,59,72,5A,73,80,84,7A secOut:26 role:04 ff:9600 ui:9600
Hvis du gir meg de verdiene, sÄ kan jeg ogsÄ fÄ den til Ä automatisk velge den DHen vedr inkludering.
Mvh Ivar
Genialt. Mail sendt!
Kristian
Hei Kristian - fikk du den til Ă„ virke?
Du for Ă„ VĂŠre ĂŠrlig funka en devicedriver til et annet panel fĂžr jeg rakk Ă„ prĂžve din🙈
Sorry, men tusen takk for hjelpa n
Kriss
@Kristian_Skauge hvilke dh har du brukt ? takk
Aeon Wallmote :slight_smile:
