Hi all
I’m testing out this new product, a Z-wave switch which fit into many countries in EU.
http://www.logicsoft.dk/index.php/zhc5010-z-wave-switch-module-for-fuga-installations
The problem is I dont know how to get the 4 buttons to work and do anything.
The switch itself was found as a “Z-Wave Device Multichannel”.
Then I installed the “Multi-Channel Control”-SmartApp from ST, which then provided my with 4 “Switch Endpoints” using the device handler type “Switch Endpoint”.
I got it to work ONCE, turning on some lights. The problem seems to be that the endpoint switch is ON all the time. According to the history of the endpoint switch, it was turned ON the day I set it up and then has not been turned off since.
I’m guessing the problem i that when ST thinks it’s ON, and I press the button again then it doesn’t do anything because it’s already “ON”.
So do I need to use a different Device Handler Type, or how do I actually use this as 4 buttons I can press and do something?
Thank you in advance
Really appreciate it
