"Heat" in Ecobee is Not Appearing as a Mode in SmartThings
Hello,
“Heat” in the ecobee is not appearing as a mode in SmartThings. all (Auto, Cold, Aux. heat Only and Off) are available except Heat (which is for heat pump). It appears to be a persistent issue with the SmartThings app, as it is unable to recognize the system mode for Heat Pump Heat. Can someone please provide a solution or a workaround
Thank you,
Ecobee supports the cloud->cloud integration so this is something they would need to investigate as to why that mode is not available in the ST app.
As a workaround,if you have a voice assistant that supports an Ecobee integration (like the Alexa skill), you can use a virtual switch in ST as a proxy to trigger an Alexa routine with a custom action to set the heat mode. I use this method because Comfort Settings aren’t exposed in the ST app either.
Thank you for the workaround. Yesterday, I reached out to ST support, provided a few screenshots (to demonstrate that ST can detect HEAT as the thermostat mode, but it is not listed as a mode), and they assured me they will address it (add it to ST).
Hi,
Any news on adding the heat to ST ?
Great news, it’s now resolved, you can see all the choices, cool, heat, aux heat, automatic and deactivated!
Yeah … I contacted both ST and Ecobee and I don’t know who resolved the problem.
I don’t need Sharptools anymore just to select the heat mode.
fantastic, thank you for notification…
