They pair fine as a basic on/off outlet in Smartthings. Does anyone know if there is a device handler for similar devices that will enable the power usage function? They look like rebranded philio PAN11 device. I managed to get the door sensor that came bundled to work of the Philio device handler
I would imagine a lot of it is to do with the availability of streaming content these days. I’m not surprised it’s rebranded, a lot of Hauppauge products actually were/are.
Just got my starter kit today with the 2 plugs and the multi sensor. Multi sensor works great with the Philio DTH. Hoping there will be a handler for the plug soon.
I went through the manuals for both the products and they are essentially a copy paste.
On/Off works, but I am getting nothing else. When you first set it up, you need to update parameters. I had errors while saving, so had to do it on the IDE.
Here are the 2 manuals I compared to confirm the two devices are same.
