Noob here but picking things up, help or a pointer required please.
I bought the above devices with the intention of fitting then to 13amp double wall sockets and being able to control individual sockets via automation in smartthings.
I’ve installed the latest device handlers from searching on here but each device which is a dual relay/switch only shows up as a single device as shown below on the My Home Things page.
What I was looking to do Is to control each Individual relay/switch with an automation, this is what i cant figure out?
Can It be done with these devices?
Is there an alternative device?
Preferably I would like each relay/switch of the device to show up as an individual device on the "My Home Things page"
I have the Philio Pan04-1b and I can’t get it working properly, That is, I can’t get its status updated (when physically switched - not through the app).
Can you post the handler you were using?
Do you experience similar issue?
