Half of things no longer work!
I went on vacation last week and set up a vacation mode that was supposed to auto turn off and turn on lights. When I left everything worked great. Now I’m home and more than 50% of my things just stopped working. Some are ge link bulbs, some are ge zwave switches. The actual physical bulb or switch works but I cannot control them at all through smartthings.
Any ideas why this would just happen out of no where, and ideas on how to fix it?
Thanks!!
Reboot your hub. That usually works
For the switches, I have been having to flip the power on and off for that breaker to reset them AFTER a hub reboot to get them to show the correct status in ST.
I think the real question is what caused it, not which hoops to jump through to “fix” it :frowning:
This. I’ve had several z-wave switches go completely unresponsive via ST over the last week or so and it’s driving me up the wall. Would LOVE to find out what’s causing this.
Unfortunately this is mostly z-waves fault. It is an ancient technology (i think it was released in the 70s) that actually has a ton of bugs in it. As a hub manufacturer you are perpertually walking on egg shells with z-wave. Here’s to hoping that zigbee becomes and more widely used protocol. It is much more stable (and about twice as fast on the communication side)
Rebooting did nothing. When I had micasa verde I never lost control of any zwave device. I love the idea of smartthings but it’s getting so finicky. Every week there’s an outtage or something stops working. I’ve had to delete (not always an easy task) things, re-pair them only to have to do it again a few weeks later. It’s getting frustrating!!
I think you have to check your facts. ZWave was introduced in North America in 2008 when Sigma Designs acquired Danish startup ZenSys. You may be confusing it with X10, which has nothing to do with Z-Wave, but rather is a grand daddy on Insteon.
I find it helpful at times to look at the Activity Feed of a device or the Live Logging in the IDE when I try to figure out an issue.
You are correct I was mistaken with the dates of x10. My apologies. Thanks Geko :smile:
Regardless of my incorrect dates, zwave tech has a TON of shortfalls that no smart solution manufacturer can control. For instance a inherent flaw where you can’t ping the device too often without it freezing up and the device REQUIRING a hard power off to “reset” itself. Smartthings ran into this a couple months ago. They may still be within the wrong range with device checks. (P.S. Zwave does not publish this value so it’s hard to discern what it is.)h
We both do actually. According to the Sigma Designs website they have had the tech for 12 years.
From the Sigma Designs Website:
“Z-Wave technology provides industry leading reliability, ease of installation, a history of 12 years with the best brands and products on the market.”
This is why almost all z-wave hard-wired devices have the airgab switch so they can be completely reset.
On the same token, after the upgrade I had to exclude and readd 4 z-wave devices 2 GE wall switches a aeon energy plug/switch, and another z-wave appliance plug.
I can’t really compare to zigbee because I only have 3 zigbee devices, 1 motion and 2 presence.
Exactly true.
As for you having to re-add the devices after the upgrade, I’m going to throw my hands in the air lol. That week/weekend was just bad lol. No doubt about it. I say we should just forget that week lol. Bad times and negative feelings and talk tend to have a way of being poisonous.
Actually, that’s patently false. The airgap is a safety feature present in dimmers only because even if the dimmer is ‘off’, the circuit is still energized.
Yes, apparently they’re counting time before ZenSys was acquired. Anyway, Z-Wave and Zigbee are about the same age. Zigbee spec was published in 2005 and I actually started working with XBee (then MaxStream) samples in 2006.
They are also on non-dimmer smart switches. Yes, this is a safety feature. When traditional switches are turned off, you can safely replace a light bulb without getting shocked. Air gaps are added to dimmers and smart switches because this is no longer the case.
According to this post, even this has potential failure:
I agree with others that an air gap isn’t very useful.
In addition, I have had switches dropped from the network where cycling the circuit breaker worked when recycling the air gap did not.
