Google Nest Cam Outdoor Battery on Smartthings
Hello,
I have acquired a couple of Google Nest Cameras and managed to configure them on the Google Home App. Through service connection I have the cameras working on Smartthings.
Unlike my Aeotec 360 the Google Nest cameras don’t have the small “button” on the widget so that I can quickly turn then on/off, nor it is possible to do so through routines/scenes. This is just an example:
I can, however, turn them on/off on the Google Home app.
My inside cameras are both Aeotec, and both Google cameras I want to place outside.
What I am trying to accomplish is to take advantage of the “Home Monitor” service and I wanted to create routines to:
  • When state is Disarm Home Monitor: Turn off all the cameras
  • When state is Arm (inside): Connect outside cameras
  • When state is Arm (outside): Connect all cameras.
Edit: I do understand the difference is that the Aeotec cameras are fully managed by my Hub/Smartthings, and the Google Cameras are linked via service. Also, I have all switches turned on at nestservices.google.com. If anyone managed to connect the Nest cameras directly to Smartthings, that would be cool too, though I doubt that is possible.
Hopefully this makes sense and someone already went through it. Thanks in advance.
I believe you get the award for smallest images posted :slight_smile:
Sorry, these are google examples. But you get the point. If you don’t, I don’t think you would be able to help anyway :upside_down_face:
I believe that Google is responsible for the integration with ST. I think that they would have to modify the integration to expose these elements in the mobile app presentation.
Hi @nf098,
I do own and have Google Nest Cameras integrated with Smartthings too, and it’s been a while having that integration and they have never allowed to do anything with the cameras (on/off switch or similar), you just can see live feed and add them to routines for motion detection only
Nest (now google) is in charge of this integration, so I would suggest reach them via [Contact Us (Contact Us - Google Nest Help) or create a post under their community https://www.googlenestcommunity.com/ and see if someone had reach out Dev for this
Cheers!
Hello,
Quick update. Although it’s not the optimal solution, I found a way to get things done…
Smartthings and Google Home are connected both ways. Smartthings has the Home Monitor, if I set “Arm away” it will connect my Aeotec 360 cameras through a Smartthings automation.
While that on the Google Home app there is an automation that when the Aeotec cameras are turned on, the Nest cameras are turned on as well… I will experiment this further but so far, I found this way of turning all cameras on with just one action: Home Monitor
For some reason I couldn’t create the automation on Google Home using the UI, but a simple Script did work.
I will update this once I finish the setup and let you guys know.
Cheers
Google in their infinite wisdom restrict camera actions in routines to time schedule starters only.
The cameras are so locked down it’s ridiculous. I mean, turning on a camera when a door opens might be useful eh? You can’t do it via the UI.
