Hi…
I am looking for support…
How could we control the Bose sound touch volume using google home?
example: Ok Google, Set the Soundtouch volume to XX %.
Thanks…
Hi…
Thanks…
Is your Bose soundtouch connected to ST? If so, you can use IFTTT to pass a numerical value to ST using WebCore, the community rules engine. That’s the only way I know to pass a number value over. That would require setting up an applet in IFTTT and then setting up WebCore with a piston and a webhooks webcall from one to the other. If this is something you want to pursue it’s going to be a lot of work. Don’t know if you wanna go through all that trouble.
