My Samsung Air conditioner with SmartThings wifi control interfaces with google home.
I can start, stop or change the temperature.
Does anyone know the voice command to change the speed of the ventilator (which is possible in the smartthing app) ?
Thereâs a guide for available voice commands available in the App:
Looks like âHey Google, set [Device name] speed to [low/high/max]â is what youâre asking about. Hope this helps!
Found it, thanks !
Strange is the fact that you can set it to âlow / high / maxâ but not to âautoâ, which you can in the app ?
Smartthings is installed in Dutch, but the commands on that screen are in English. So I tried to translate themâŚthe only thing I can for the moment is setting it to low and setting it higher (so one step higher)âŚ
Hello,
I am trying to find out what commands are available for my windfree ac.
When I click on voice assistant (step 3) it shows learn more (and alsoâgoogle assistant is connected with smartthings)
When I click that (step 4) it shows âunknown errorâ. The only thing what works: exit.
Do I do something wrong?
Has any an overview of the possible voice commands?
