Cannot find any either. Was sure I saw some before but all seem to be in US .
Is seems to be a dogâs dinner of a mess. Have similar with Magic Home with my LED lights. Do you have any recommendations for ST compatible LEDs controllers. All seem to be Magic home any from one Iâve sourced in China that reports to be Smartlife and hopefully globe/ST compatible.
Does anyone have a list of âofficialâ globe compatible bulbs. Just starting with ST and buying a couple of different devices to test. I have 40 smart life device in there SL product. The plan was to slowly unlink from smart life and re install in to Globe so that ST sees them and I can do some Applets in both ST and IFTTT. But if some devices are not compatible with ST integration then I need to rethink my strategy. Too many acronyms
Thanks andy
Have you considered whether any of your magic home controllers will run tasmota ? I just flashed 3 old teckin plugs (Which used to work with ifttt, then globe suite but not at all) using tuya convert (No soldering, itâs an OTA flash using a raspberry pi) You then use this smart app to bring them under ST control - [RELEASE] Tasmota (Connect) for Sonoff, Tuya, SmartLife & other ESP8266 devices)
Itâs less complicated than it seems from this thread.
Globe Electric is a Canadian device manufacturer. Their SmartThings integration works only with devices of their own brand.
If itâs not one of their products, it doesnât work with their integration. Both the product box and the device itself will have the company name on it.
For devices from other manufacturers, first look for their brand in the smartthings app. If itâs not there, see the community FAQ for other possible options:
And specifically regarding Ifttt and smartlife, see the following thread:
Zooz, Qubino, Fibaro and Monoprice all make LED strip controllers that work with SmartThings.
Which makes sense. I never understood why people started to DEMAND the integration to work NOW, when they didnt event had bought Globe products.
the âswitchesâ in my âGlobal Suiteâ dose not show in up in Smartthings after link the Global Suite account to Smartthings.
that one âSmart lifeâ actually is not working when you try to link together it will show the network err
Are your switches âglobe manufacturedâ devices? Only Globe devices will work in this integration.
