Let me see if I understand you correctly. You installed the device named “Bedroom” but then deleted it.
However, you keep receiving events from it in the logs and you cannot pair it again, correct?
Try to restart the Zigbee device to the default config, this should trigger an unpair event and in the logs, you should receive the “removed” lifecycle.
Sure, what I mean is restarting the physical device to its manufacturer configuration. The process depends on each manufacturer, but generally, you need to press a button for several seconds.
I have already restarted the device and even paired-unpaired it with another hub. So device is ok.
The issue is in ST driver so apparently, it was not unpaired fully and stayed in some internal device list. I already even restarted the hub, no luck
2021-09-30T19:26:11.038416708+00:00 INFO Xiaomi Switch <ZigbeeDevice: fc0198f9-6a26-43d8-b73e-fb1a7d2382bc [0x11A8] (Bedroom)> received lifecycle event: infoChanged
Yes, I agree that it wasn’t unpaired correctly, that’s why we need to trigger the unpair event from the physical device so the corresponding Hub receives it.
Restarting the Hub won’t work, this process could help us, you might need to do it more than once until you receive the “removed” event.
If after this, you still cannot delete the device, please provide this info by DM:
yesterday I have paired next to the last device (Bedroom) and started to move my rules from SmartLights app to automations in the iOS app.
there were several “network” errors but then I just ignored themre and clicked “retry” couple of times
went for a short walk approximately at same time
when I came back I found out that all of my automations and scenes went missing and when I tried to create an automations I kept getting the same “network error”
next morning I tried to use my Android phone and had the same issue with automations.
And also one or two “Untitled” devices with no detail page. One of them was apparently the fc0198f9-6a26-43d8-b73e-fb1a7d2382bc .
I removed these devices and tried to re-pair that device with no luck. Reset/reboot of everything did not help.
I reset the device and get it connected it to another hub.
so it’s probably a server problem and my actions combined. My best guess is that I was making changes when one of the servers went down and some of the settings were lost .
most likely, I do not remember. As it said “Network” I did not pay much attention.
Before creating the automation, did all the capabilities work correctly?
well, there were no errors in the log.
But I am not a LUA programmer, half of my driver is copy-paste from samples another half is the co-pilot auto-completions.
So it’s possible those devices were only driver-based?
Sure, I already created a report about this, the engineering team will be able to analyze the issue if your device is still in the same status. I’ll let you know about the progress.
