I’ve just picked up a couple of Osram Lightify CLB 40 Tuneable White (E14) bulbs (without a hub). All my Googling suggested they’re compatible with the ST hub, but they’re only being detected as ‘Thing’ when I go to connect a new device. I guess there’s a missing device definition?
We are working on the Osram integration in the UK. I believe the A-shape bulbs will work out of the box, but there might be a slightly different firmware on the CLBs.
Hi Aaron, seems to work well so far using ‘OSRAM LIGHTIFY LED Tunable White 60W’ - tuneable white works well too. Not sure what firmware they’re running as don’t have the Lightify gateway so can’t check or upgrade, but maybe it’s in the screengrab I posted earlier?
My observation is that once you start adding more than a dozen or so of the osram bulbs directly into ST stability of zigbee sensors go to pot. I have had months of pain trying to figure out the root cause until I moved them all into hue.
I wouldn’t recommend adding any until ST fully certify them officially.
