The stock and frequently used custom handlers see the Fan Control as a dimmer so you can control via Alexa like a dimmer telling it to set to 33, 67, 100 or whatever numbers correspond to something your fan sees as its various speeds. Another option is to use the following custom handler that sets up child devices for each speed which you can then turn on or off via Alexa.
