I have purchased the following outlet, seeing in the compatible products list:
however, now when i go and try to connect it, its not listed.
please let me know what should i do regarding this.
You can just use “Connect New Device” and it will find it and set it up with a compatible device type. In most cases, you do not need to select the specific thing that you are connecting since it can be determined automatically by the device’s fingerprint.
I have several of those outlets, and they show up as a regular z-wave switch.
When you go to connect you can either just tap on Connect New Device or select Lights & Switches -> Outlets -> Jasco to find that outlet (they’re really Jasco devices).
Got, it, thank you, that worked.
