GE 12726 40 amp outdoor switch
my first post after converting to ST from Vera.
I have installed GE 12726 outdoor switch and have connected tow separate 110V appliances to it and successfully paired it to ST, but I can only see one device and I don’t see how I can control each device separately.
according to JASCO (GE) the device does support ability to control each device separately but I have not been able to do it.
So my question is, whether ST can control each switch independently?
Cheers,
Armen
This module is not a dual relay module. There is only one relay inside. You could hook up 2 120VAC loads to it but you cannot control them individually.
Ray,
Thanks for reply, after talking to Jasco support apparently the device does support it, but they did not have any Hub currently that will work with it, so I am wondering how can we make it work within smartthings?
You would have to get the manufacturer to provide the api details and modify or create a custom device driver for it.
Now that’s interesting and sorry for my assumption. As for how to get it working. I am not much help again since I don’t know much coding. You can try this little Z-Wave tweaker and see all the parameters of the device and there are a couple of Z-Wave dual relay module DTH with simulated switches to operate the 2 loads. Maybe give it a try and see if you are lucky.
Thanks for the reply, I installed the Zwave Tweaker and it does not look like it support multichannel commands, so I assume it is not deal relay unfortunately, I wish I knew it before buying and installing it, I replaced old intermaticc unit that did and was just acting up once in a while.
