GE 28177 dual outlet
Does anyone know how to set up this dual outlet with Smartthings? Both outlets are supposed to be able to be controlled independently but I can only see and control one through Smartthings. I switched the DTH to “Z-wave device multichannel” but I still only see one outlet to control. Thanks for your help.
As per Amazon:
  • INDEPENDENTLY CONTROLLED OUTLETS REQUIRE HUBS TO FULLY SUPPORT Z-WAVE MULTI-CHANNEL (Wink & Vivint Only) – IF HUB DOES NOT SUPPORT THIS FEATURE BOTH OUTLETS CAN ONLY BE CONTROLLED TOGETHER
So the real question is if the ST hub supports Z-Wave Multi-Channel…
J
https://community.smartthings.com/search?context=topic&context_id=143242&q=%20multi%20channel&skip_context=true
I don’t know, GatVlieg. Let me be a bit more specific so as to prevent any more useless replies like posting a search link. I tried searching and haven’t found anything definitive. It seems like there was a multichannel smart app that has since been discontinued. So it sounds like Smartthings is multichannel capable. There is also a Z-wave tweaker app that is mentioned with multichannel quite a bit but I’m not sure if that’s what I need. If anyone happens to know how to get this to work or even if it will work I would appreciate it. Right now I have one outlet working but it would be great to get both functional. Thanks.
