I have installed Actiontiles on my tablet for all my automation. I can not open the garage doors using the tile. All other functions work well. Does Action tiles not permit opening the garage doors.
Mine works fine. However, it does prompt me to verify I want to open it. What browser are you using?
Are you running a SmartApp for your Garage door? I’m running MyQ Lite and when I press on the tile, it asks me if I want to open, then when already open, asks me if I want to close.
MyQ also allows for on / off button (opener / closer) devices to be added and those can be added as tiles in AT as well. If I use those as tiles, it immediately opens or closes without asking.
Google chrome
ActionTiles is fully compatible with compliant Garage Door Device Type Handlers… ref: http://docs.smartthings.com/en/latest/capabilities-reference.html#garage-door-control
- What type of Garage Door hardware are you using?
- What Device Type Handler are you using (the SmartThings default or a custom one?).
- What happens when you observe Live Logging attempting to operate the Door from ActionTiles (https://account.ActionTiles.com)
For direct assistance, please also send the above answers to Support@ActionTiles.com
Also if you are using MyQ Lite I know there have been a couple updates recently. Might just need to update it.
Hi, I am using Garadget openers, Custom device type handlers Logs4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 11:01:11 PM: debug returnedresult: status=closed|time=5h|sensor=98|base=3379|signal=-504e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 11:01:11 PM: debug Output status: 2004e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 11:01:11 PM: debug Executing parseDoorStatusResponse: [result:status=closed|time=5h|sensor=98|base=3379|signal=-50, cmd:VarReturn, coreInfo:[last_handshake_at:2017-12-03T14:51:30.571Z, last_app:, product_id:355, deviceID:490042000551353530353431, connected:true, last_heard:2017-12-04T04:01:11.735Z], name:doorStatus]4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 11:01:11 PM: debug Executing 'sendCommand’4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 11:01:11 PM: debug Http Params ([uri:https://api.particle.io, path:/v1/devices/490042000551353530353431/doorStatus, requestContentType:application/json, query:[access_token:17922b4771b3383649a7efb8afc9389cbb918cf5]])4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 11:01:11 PM: debug Executing 'sendCommand.statusCommand’4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 10:56:11 PM: debug returnedresult: status=closed|time=5h|sensor=98|base=3378|signal=-504e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 10:56:11 PM: debug Output status: 2004e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 10:56:11 PM: debug Executing parseDoorStatusResponse: [result:status=closed|time=5h|sensor=98|base=3378|signal=-50, cmd:VarReturn, coreInfo:[last_handshake_at:2017-12-03T14:51:30.571Z, last_app:, product_id:355, deviceID:490042000551353530353431, connected:true, last_heard:2017-12-04T03:56:11.420Z], name:doorStatus]4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 10:56:11 PM: debug Executing 'sendCommand’4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 10:56:11 PM: debug Http Params ([uri:https://api.particle.io, path:/v1/devices/490042000551353530353431/doorStatus, requestContentType:application/json, query:[access_token:17922b4771b3383649a7efb8afc9389cbb918cf5]])4e9a74fc-ecc0-4e4b-bcbb-f380da6abde9 10:56:11 PM: debug Executing ‘sendCommand.statusCommand’ Thanks,Atily
tgauchat ActionTiles.com co-founder Terry @ActionTiles; GitHub: @cosmicpuppy; NOT a SmartThings Employee. Helpful
December 4 |
Atily:
Visit Topic or reply to this email to respond.
To unsubscribe from these emails, click here.
I open my garage door with ActionTiles so it definitely should work. Does yours open and close through the standard SmartThings app?
Officially, we don’t have the resources to debug non "Works With SmartThings"™ devices. You may need to request support from its developer.
But if you provide a link to the Device Type Handler code, we or other folks may see something by looking at it.
Yes it does
Which DH’s are you using?
I want to replace my ON/OFF “opener” and “closer” switches in AT with what you are showing.
Thanks!!!
The Garage Opener and Garage Closer devices were automatically created when walking through the MyQ Lite setup screens so I didn’t need to create any additional Automations to tie that to the Garage door. It’s built into the SmartApp as to whether I press the Closer or the Opener.
So adding those devices to ActionTiles and when pressing them, they are already tied to the MyQ SmartApp.
As for the Device Types that both of those devices use is “Momentary Button Tile”
Thanks… It showed up after refreshing. Works GREAT!
Can you tell us which device handler and which smartapp you are using? Mine only opens my garage without ever prompting me if I want to open the garage. A second press does nothing as it only sends an open command.
I am using Garadget openers and their DH. It works with Alexa , IFTT and Classic ST. I downloaded the new ST app.I find it does not have the ability to monito my security system
