For the last couple of weeks at the top of my dashboard next to the monitoring tile I have a notification that says my garage doors are open. Both doors are currently close and have been opened and closed multiple times since this started showing up. When looking at the garage door sensors they show as closed. Does anyone know why this would be showing like this and how I can clear it?
You referred to the item under Favorites as “doors”, so is that a virtual switch that you created and made a favorite to aggregate the status of both doors? If so, I’d check the routine (or whatever you used) that drives that virtual to see why it might be displaying the incorrect status.
. … Although I’m wondering based on its location on the page if ST created it. I have garage doors on Go Controls but I have not seen a ST created object like that.
I’m having the exact same problem. My garage door has been been showing at the top of the ST app as open for two weeks, but when I tap to actually view the garage door, it shows the proper status. I’m using a Go Control door opener with @RBoy 's Enhanced Z-Wave Garage Door Controller DTH. It’s driving me nuts!
