Hi, i bought one of the new samsung multi purpose sensors and it works fine for the most part, however i have 2 problems.
the battery has decreased by 40% in under a week. This doesn’t seem normal.
i tried to create an automation using the new app. When my phone leaves home and the garage door is open, it should send me a notification. This i tested but i never ger the notification.
The sensor is configured to be used as a garage door sensor and does indicate correctly whether the garage door is open or closed. I only mounted the main part. I did not mount the smaller piece.
