Im trying to get my Foscam FI8910W working with ST and, admittedly, I am a html newbie :-/
I tried using @imbrian code but cant get it working… can anyone offer any guidance?
Some of the errors I get are:
12:03:29: error java.net.UnknownHostException: null: Name or service not known @ line 263
12:03:29: debug http://null:null/get_params.cgi?user=null&pwd=null
12:03:32: error java.net.UnknownHostException: null @ line 259
12:03:32: debug http:/null:null/snapshot.cgi?user=null&pwd=null&
12:03:32: debug Take a photo
12:07:20: error java.net.UnknownHostException: null: Name or service not known @ line 259
12:07:20: debug http://null:null/set_alarm.cgi?user=null&pwd=null&motion_armed=1
It looks like your parameters (ip, port, username and password) have not been set. Here are the step-by-step instructions for setup of the NON-local Foscam (meaning, you’ll need port forwarding or an otherwise publicly accessible camera to use it):
It looks like you aren’t putting in parameters after you’ve created the device type. I used the same code from imbrain, I have the Foscam 8910W, and I need to change one line to get the snapshot to work, because the Foscam model was different.
@tslagle13 - kind of. I have a working local IP control that I’m using myself, but the polling for finding alarm state isn’t working. I may try and pick at it again as I find time. Wasn’t sure where the problem was, so was waiting for support from the ST side.
Ok so I got it to arm and it supposedly completes tasks like capture image and poll… but where does all that go? I dont see any activity in the ST app itself. I dont see the pics its taking.
I do have the motion alert and email set up in the Foscam settings. What am i missing?
@imbrian I’m working on something similar. I can “ping” devices using local lan control but am having trouble handling any responses (which, with the foscams would presumably include the pictures). When you trigger the alarm state do you get a response from the camera to verify? Can you share some of that code if you do?
@mattmartz - I’m able to issue commands from the hub to the camera. It doesn’t reply with anything useful in terms of alarm status - and even if it were, you’d still want to poll to ensure the alarm wasn’t activate by some third party means. Fortunately, there is an endpoint that provides that value: /get_params.cgi
Within that call, it’ll have a line that either reads var alarm_motion_armed=0 or var alarm_motion_armed=1 - by which, you can then set the device state. I have that working for the direct version of the controller: https://github.com/imbrianj/foscam/blob/master/foscam.groovy But I’m having issues parsing the reply on the local IP version. I’m working with @dlieberman to sort it out and will post what I have once I have something working.
I am completely new to developer section of ST. FI8910W is the first thing I am trying to add to ST. I set up the device handler by copying pasting your code (@imbrian). I added a device and then set up the username, password, IP and port from the ST mobile app. I tried to run it and got this error:
8:59:33 PM: error org.apache.http.conn.ConnectTimeoutException: Connect to 192.168.1.201:8008 [/192.168.1.201] failed: connect timed out
8:59:23 PM: debug http://192.168.29.201:8008/set_alarm.cgi?user=&pwd=*&motion_armed=1
I was able to log in to the camera via web w/o problems, so IP, port, username and password should be correct.
Any help would be appreciated!
