And here is a private message I had sent to another user on how to get his foscam set up using the above code:
Yes – you first need to add a custom device type. That will define what your inputted device is and how it works.
Visit https://graph.api.smartthings.com/ide/devices and click ”New SmartDevice” in the upper right corner.
Give it the Name of ”Foscam” – author can be whatever you want. In ”Capabilities”, select ”Image Capture” and ”Polling”.
Under ”Custom” enter these attributes: ”setStatus” and ”alarmStatus”.
Under ”Custom” enter these commands: ”alarmOn”, ”alarmOff”, ”left”, ”right”, ”up”, ”down”, ”pause”, ”set”, ”preset1”, ”preset2”, ”preset3”, ”toggleAlarm” and ”preset”.
Click ”Create” – it’ll drop you to the coding IDE. Just paste in this source code: https://raw2.github.com/imbrianj/foscam/master/foscam.groovy
Save and Publish
You now have the custom Foscam device type installed – you’ll need to install your specific device. You’ll need to have a port open to access it from the ST cloud. Once it’s configured to accept connections externally, go to ”My Devices” and click ”New Device”.
Enter the ”Name”: ”Foscam”, ”Device Network ID”: ”Foscam”, ”Type”: ”Foscam”, ”Location”: wherever the device lives, ”Hub”: LEAVE EMPTY.
When you’re a the details page for this devices, there’s a ”Preferences” section near the bottom. Click ”edit” and enter your username, password, IP address (or dns address) of the camera as well as the port used.
You should now have the device installed and it should be able to respond to events.
The foscam.groovy is used to tell SmartThings how to turn the alarm on – but you’ll need a smart app (or direct interaction with the app in the menu) to actually arm it. You can create a new smart app and take my code here: https://raw2.github.com/imbrianj/secure_my_foscam/master/secure_my_foscam.groovy and configure the app to arm or disarm based on a particular mode (the most logical being ”arm” for away, ”disarm” for home).
Hope this helps – let me know if you have any questions.
