Forcing/Returning an icon back to default?
I have the following set up to define the icon for my tile in one of My Device Types called Better Momentary:
icon: “st.doors.garage.garage-closed”
I used the code for a SmartSense Virtual Momentary Contact Switch, and changed it to my liking, but I decided to change the icon via the phone app and now I don’t know how to get back my default setting. I’m sure there’s something I don’t know how to do, so I’d be grateful for any help. Thanks!
  • JC
Did you find a solution for this? I have the same issue and really don’t feel like removing and re-adding the devices simply to get the default icon back.
This thread is 4 years old, and there’s been a few newer posts about this topic. It all depends on the DTH you’re using. If it’s a custom one, then you can modify your code to allow for changing icons, remove/readd the device, or email support to have them change the device’s icon.
If you’re using an ST default DTH, then you’ll have to email support if Device Preferences isn’t giving you any options.
