Fire/CO2 alarm dilemma
I had a roof leak which damage my Fire/CO2 alarm.
In my house I have 4 hardwired Fire/CO2 alarm and the main unit damaged.
The main unit is Kidde KN-COSM-ICA (Expires Nov 2016) <<< Damage
Auxiliary units are Kidde i12020CA (Expires Nov 2019)
I was wondering if there are any z-wave Fire/CO2 alarm I could purchase to replace the main unit.
I notice Home Depot has a WINK unit which is Kidde 900-0225CA and hope this could work with ST.
Or can I Intergrate First Alert ZCOMBO-G?
Any solution is welcome.
I have 3 Zcombo from Lowes. All connected to ST well.
I was hoping to get 1 alarm which could be hardwired to my current system.
There aren’t any. You would have to replace the main unit with a similar one that was there before. You could then use the appropriate interconnect relay and a monoprice or schlage type open/close sensor and a custom device type to put it all together in ST.
Connected Smoke Alarm project: Connected Smoke Alarms
Kidde relay: http://www.amazon.com/Kidde-SM120X-Detector-Hardwired-I-Combo/dp/B001AYERC2
Though, I will add, on edit - using the monoprice type sensor (and ecolink, maybe??) those sensors have contact terminals and are more easily used than the schlage type that requires solderinig. Here’s the device type I used for mine:
  • Z-Wave Door/Window Sensor
  • Author: SmartThings
  • Date: 2013-11-3
// for the UI
metadata {
// Automatically generated. Make future change here.
definition (name: “Monoprice Door/Window Sensor as Smoke Detector v2”, namespace: “trostc”, author: “trostc”) {
//capability “Contact Sensor”
capability “Smoke Detector”
capability “Sensor”
capability “Battery”
//0 0 0x2001 0 0 0 7 0x71 0x85 0x80 0x72 0x30 0x86 0x84
fingerprint deviceId: “0x2001”, inClusters: “0x71, 0x85, 0x80, 0x72, 0x30, 0x86, 0x84”
// simulator metadata
simulator {
// status messages
status “clear”: “command: 2001, payload: FF”
status “detected”: “command: 2001, payload: 00”
// UI tile definitions
tiles(scale: 2) {
multiAttributeTile(name:“smoke”, type: “lighting”, width: 6, height: 4){
tileAttribute (“device.smoke”, key: “PRIMARY_CONTROL”) {
attributeState “clear”, label:‘${name}’, icon:“st.alarm.smoke.clear”, backgroundColor:“#79b821”
attributeState “detected”, label:‘${name}’, icon:“st.particulate.particulate.particulate”, backgroundColor:“#ff1f1f”
  valueTile("battery", "device.battery", inactiveLabel: false, width: 2, height: 2) {
  	state "battery", label:'${currentValue}% battery', unit:""
  standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
  	state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
  main "smoke"
  details(["smoke","battery","refresh"])
log.debug “parse:${description}”
def result = null
if (description.startsWith(“Err”)) {
result = createEvent(descriptionText:description)
} else if (description == “updated”) {
if (!state.MSR) {
result = [
response(zwave.wakeUpV1.wakeUpIntervalSet(seconds:4*3600, nodeid:zwaveHubNodeId)),
response(zwave.manufacturerSpecificV2.manufacturerSpecificGet()),
} else {
def cmd = zwave.parse(description, [0x20: 1, 0x25: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1])
log.debug “parse:cmd = ${cmd}”
if (cmd) {
result = zwaveEvent(cmd)
return result
def sensorValueEvent(value) {
log.debug “sensorValueEvent:value = ${value}”
def result = null
if (value) {
result = createEvent(name: “smoke”, value: “clear”, descriptionText: “$device.displayName smoke is clear”)
} else {
result = createEvent(name: “smoke”, value: “detected”, descriptionText: “$device.displayName detected smoke”)
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
sensorValueEvent(cmd.sensorState)
def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd)
def result =
if (cmd.notificationType == 0x06 && cmd.event == 0x16) {
result << sensorValueEvent(1)
} else if (cmd.notificationType == 0x06 && cmd.event == 0x17) {
result << sensorValueEvent(0)
} else if (cmd.notificationType == 0x07) {
if (cmd.v1AlarmType == 0x07) { // special case for nonstandard messages from Monoprice door/window sensors
result << sensorValueEvent(cmd.v1AlarmLevel)
} else if (cmd.event == 0x01 || cmd.event == 0x02) {
} else if (cmd.event == 0x03) {
result << createEvent(descriptionText: “$device.displayName covering was removed”, isStateChange: true)
result << response(zwave.wakeUpV1.wakeUpIntervalSet(seconds:4*3600, nodeid:zwaveHubNodeId))
if(!state.MSR) result << response(zwave.manufacturerSpecificV2.manufacturerSpecificGet())
} else if (cmd.event == 0x05 || cmd.event == 0x06) {
result << createEvent(descriptionText: “$device.displayName detected glass breakage”, isStateChange: true)
} else if (cmd.event == 0x07) {
result << createEvent(name: “motion”, value: “active”, descriptionText:“$device.displayName detected motion”)
} else if (cmd.notificationType) {
def text = “Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(”, “)}”
result << createEvent(name: “notification$cmd.notificationType”, value: “$cmd.event”, descriptionText: text, displayed: false)
} else {
def value = cmd.v1AlarmLevel == 255 ? “active” : cmd.v1AlarmLevel ?: “inactive”
result << createEvent(name: “alarm $cmd.v1AlarmType”, value: value, displayed: false)
result
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd)
def result = [createEvent(descriptionText: “${device.displayName} woke up”, isStateChange: false)]
if (!state.lastbat || (new Date().time) - state.lastbat > 5360601000) {
result << response(zwave.batteryV1.batteryGet())
result << response(“delay 1200”)
if (!state.MSR) {
result << response(zwave.wakeUpV1.wakeUpNoMoreInformation())
result
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: “battery”, unit: “%” ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = “${device.displayName} has a low battery”
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbat = new Date().time
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result =
def msr = String.format(“%04X-%04X-%04X”, cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug “msr: $msr”
updateDataValue(“MSR”, msr)
retypeBasedOnMSR()
result << createEvent(descriptionText: “$device.displayName MSR: $msr”, isStateChange: false)
if (msr == “011A-0601-0901”) { // Enerwave motion doesn’t always get the associationSet that the hub sends on join
result << response(zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId))
} else if (!device.currentState(“battery”)) {
result
createEvent(descriptionText: “$device.displayName: $cmd”, displayed: false)
def retypeBasedOnMSR() {
switch (state.MSR) {
case “0086-0002-002D”:
log.debug(“Changing device type to Z-Wave Water Sensor”)
setDeviceType(“Z-Wave Water Sensor”)
break
case “011F-0001-0001”: // Schlage motion
case “014A-0001-0001”: // Ecolink motion
case “0060-0001-0002”: // Everspring SP814
case “0060-0001-0003”: // Everspring HSP02
case “011A-0601-0901”: // Enerwave ZWN-BPC
log.debug(“Changing device type to Z-Wave Motion Sensor”)
setDeviceType(“Z-Wave Motion Sensor”)
break
