Finally! In new APP: Automated presence based Arming/Disarm/Intruder Alert and Reminders
I went thru tons of forum threads and mostly all were good but either for whatever reason did not work for me or are based off the now sunset SmartThings mobile app (classic).
It took some tries and retries but finally I have a working version with some “help” from external units to achieve my objective. Here’s what and how I was able to do it.
Prerequisites / caveats: All of this is based off iPhone (I don’t know how it’ll work in Android but should be similar). Secondly, one needs Alexa (Amazon) to be installed in each mobile phone whose presence is required to be tracked. The location service must be set to “Always” for Alexa and it should be always running in the background. Oh and yes: webcore.
Step 1: Using the Groovy IDE I created 4 virtual switches and placed them in its own group - Virtual. They are vDad, vMom, vSon, vDaughter.
Step 2: In Dad’s phone I created 2 routines. These routines are individually created in each phone. This is because Alexa routine only allows one to track “This Device”.
Step 3: In Alexa I carefully play around and ensure by “Home” I have a really well defined area on the map. The good part is definition of “home” can vary for each member! Thus, for my 2 children the “Home” defined is relatively a very condensed space around my home while for my wife & I its relatively bigger.
Routine 1: Dad coming home
Trigger: When Dad's Device arrive home
Alexa Will: vDad = ON
Routine 2: Dad leaving home
Trigger: When Dad's Device leaves home
Alexa Will: vDad = OFF
These 2 routines are embed by creating them in each device. Thus, we need up have 2x4 = 8 routines.
One may wonder why Alexa when SmartThings itself has member locations. Try as much as I could that darn thing never ever worked as envisaged. One day it does work, next day it doesn’t. Ditto with Webcore Presence sensors also. Extremely unreliable. I reverted to Alexa as it’s been 200% stable. I also found stable was Tile app and its tracking
Step 4: In SmartThings Automation I created few scripts. They are listed below:
1. If Location Home = Home , SHM = Disarmed.
2. If Location Night = Home , SHM = Armed (Stay).
3. If Location Away = Home , SHM = Armed (Away)
This was required because after trying to play around directly with SHM, i.e. trying to set them it never worked perfectly.
Step 5: In Webcore and NOT in SmartThings I ended up creating the Goodbye and Welcome routines. I did not need the native automation because once again I saw very strange behavior, i.e. one day works next day doesn’t.
Piston #1 = Welcome
settings
  disable automatic piston state;
end settings;
execute
if
  Any of vDad's, vMom's, vDaughter's or vSon's switch changes to on
then
  Set location mode to Home *(only while Away, or Night)* ;
end if;
end execute;
Piston #2: Goodbye
settings
end settings;
execute
if
  Any of vDad's, vMom's, vDaughter's or vSon's switch changes to off
then
  if
    All of vDad's, vMom's, vDaughter's or vSon's switch are off
  then
    Set location mode to Away;
   end if;
end if;
end execute;
The point here is - when trying to do this in the new app via an automation, setting the location mode is flaky at best. Thus switched to webcore. Also you’ll see in goodbye there’s an IF condition. I found webcore working best when there’s a “CHANGE” trigger
At this point I can safely say for the last +30 days this (above) has worked 100% of the time’
STEP 5: Good Night and Good Morning
For good night routine I used Smart Lighting smart app to create a script which keeps setting a virtual switch “Family Present” to On by checking for movement on specific motion sensors between time X to Y in the evening. If no movement for 30 min., then switches off the virtual switch. Smart Lighting programs are great since they keep resetting the timer every time there’s movement.
Then via a smart automation all I do is to set location = Night, if Family Present = OFF.
For good morning routine - it’s mostly the reverse. i.e. via a smart automation time between X and Y in the morning if motion is detected then flip the Family Present to ON. set location = HOME.
As you’ll observe here - I didn’t need Smart Lighting for Good Morning since I immediately make the home disarmed if there’s movement. However one can make that fancy too mirroring good night.
STEP 6: EXTRAS!! EXTRAS!! EXTRAS!!
All of the above works fine and dandy but I always had an issue where if the member’s phone died/not present/etc. then this won’t work and a lot of bad things will happen. For you see, I happen to have a Jerry-rigged 150 dB siren which goes off if security breached. That entire thing is controlled via SmartThing’s own response if a security event is triggered with a gap (delay) of a minute.
So here’s what I did in addition
Created another virtual open/close called vTickTock
Then, added this piston via webcore:
settings disable automatic piston state; end settings;
define
integer BlinkDurationOn = 5;
integer TimesOn = 10;
integer BlinkDurationOff = 3;
end define;
execute
if
   Any of Back Door Open Close's, Front Door Open Close's, or Side Door Open Close's contact changes to open
then
  with vtickTock do
               Open *(only while Daytime, Away, or Night)* ;
   end with;
end if;
while
   All of Back Door Open Close's, Front Door Open Close's, and Side Door Open Close's contact are closed
   and
   vtickTock's contact is open
do
   with vtickTock do
       Close *(only while Home)* ;
    end with;
end while;
end execute;
Then in Alexa, I created a routine which if it finds vTickTock to be opened, starts doing “tick tock” (Under sounds in Routine@Alexa). I had to manually add the tick tock at least 20 times. This is important since there’s a delay of a minute (in SmartThings before Siren kicks in). Thus, wanted to have a repetitive tick tock for at least approx. a minute. Only way to do that is to keep adding the tick-tock sound again and again in the Alexa routine. I calculated this and had to add it 18 times.
BTW: Anytime home is moved to HOME mode, the ticking stops since the sensor closes. Movement to HOME mode is done via the smart app (by whoever enters the phone) or via a secret phase to Alexa.
I know if I had a chime or something might have been easier but I wanted to keep devices to minimum. Also by using the messaging feature of Alexa routine I am able to generate this tick tock across all my Alexa devices simultaneously.
I have tested this with my children who regularly forget their phones, etc. I had a chimer before (Ring) but this works 100 times better. They call me to curse me but always end up moving the home into HOME mode before that. I have some secret message they utter to Alexa and home gets disarmed
So - I now have a working version of goodbye, welcome, good night and good morning. I also have a reminder routine just in case something fails or home does not get disarmed automatically. All of which is working perfectly for +30 days now. I also have the final routine which is triggered if there’s really an issue, i.e. the siren comes on
Final piston - is intruder alert, i.e. my strobe, siren all goes off.
For siren - as and when its triggered I have integration with IFTTT. There I have registered to generate a phone call to me as and when Siren get’s tripped.
Then also using webcore when siren gets tripped I have a piston which flashes all my lights in 2 groups. i.e. few lights in the front portion of my home goes on when back portion is off and vice versa. Couple this with the 150 dB siren + strobe (outdoor) Lights and the IFTTT generated phone calls I have the intruder side covered.
while
  Siren's switch is on
do
   with {group1Devices} do
        Flash on {group1FlashOn} seconds / off {group1FlashOff} seconds for {counter} times *(only while     Away, or Night)* ;
    end with;
    with {group2Devices} do
        Flash on {group2FlashOn} seconds / off {Group2FlashOff} seconds for {counter} times *(only while Away, or Night)* ;
     end with;
end while;
end execute;
Group 1 and Group 2 are set of lights spread across my home into 2 groups. They have different flash ON/OFF timings and counter can even be just 1 since as long as siren is ON this piston will trigger
STEP 7 : Work in progress. I am looking to see how I can leverage IFTTT to see if I can ping and get status of the hub. If I am not able to ping the hub for (say) XX seconds : call me. I want to do this to account for a scenario where someone cuts my Internet connection. Will post once I have a working version.
STEP 8: Normal (Home) mode notifications
I have 3 exit doors and each has it’s own open/close sensor. Every time door is opened, I have an Alexa routine detecting it (since open/close sensor opens) and does a nice sound. My children love it since we keep changing it - currently its Halloween based!! LOL
Final thing: My children are of an age they can stay comfortably home without us. The issue I had there was how to arm when we’re not home and only they are - either together or alone.
For this, using the Groovy IDE I created a special location mode: DAYTIME and then added a smartapp routine which is
If DAYTIME ; SHM = Armed (Stay)
To activate this once again via webcore I have this routine.
define
integer dAlone = 30;
integer sAlone = 30;
integer pAway = 60;
end define;
execute
while
vSon's switch stays on for {sAlone} minutes
and
All of vDad's and vMom's switch stay off for {pAway} minutes
and
vDaughter's switch stays on for {dAlone} minutes
and
All of Back Door Open Close's, Front Door Open Close's, and Side Door Open Close's contact stay closed for {sAlone} minutes
do
Send PUSH notification "Switching on DAYTIME (ARMED) mode" and store in Messages *(only while Home)* ;
Set location mode to Daytime *(only while Home)* ;
end while;
end execute;
The while condition is repeated with various options to account for just son / just daughter, etc.
Note: If doing this - carefully evaluate impact to other goodbye/welcome/etc. routines/pistons due to this new location mode = daytime
FYI… webcore will be phased out when groovy is shut down
The Smart Lighting app will also be removed at that time.
Announcement | Changes to our Legacy SmartThings Platform
JD/wkp: I have a Groovy SmartApp that today calls a webservice which returns JSON that I parse to determine when to change location mode. To prepare for the transition away from Groovy, what will I need to do in the newApp model make this work? What threads should I read to prep?
Two items to look at… Rules API and Automation Studio. Note that neither have not been finalized at this point so probably only recommend checking/testing them out but not go into full production.
@baivab Nice write up and nice solution, something we have been missing with this new app. Thanks for sharing with the community. The Debby Downer comments are unnecessary as they refer to things still in beta, not working fully, some are paid for, and certainly not workable to the average user, so unhelpful.
Was thinking the same thing. Not sure why. Thanks for the feedback. My take is simple - as and when whatever happens - happens. Till such time, this will function. Historically, Samsung has been pathetic with issues with every new something. Probably - as and when Groovy is sunset makes more sense to move to Hubitat than sticking around here.
Everyone probably is aware of it. Not sure of the context here.
Why not put these in your own thread rather than hijaking this thread?
No they’re not, I answer the question daily. Many are very suprised to learn groovy sunset isn’t as far off as they expected and do not understand the ramifications of what it means.
A year ago you would be correct, but at this point the shut down for most of the tech backing the solution described is due to be sunset. Within months, not years, so if there is someone out there trying to read this to understand how to do it themselves, we owe it to the reader to understand this may work right now but in the very near future it won’t abd start discussing how it works in the new world order. Burying our collective heads in the sand and hoping it doesn’t happen is nit a good solution.
My bad—I wasn’t listening closely, and thought the question was from the OP here. You are quite right that my response was off-topic for this thread, and I have moved it to a new one. My apologies for any confusion.
Valid point. Thanks for bringing in community awareness. I architect and design micro services using APIs for a living. Till date, what I have read in terms of the approach being provided leaves me with many questions. I’d continue with what I have and presented here till they (Samsung) pull the plug on Groovy and after which will move to Hubitat - 100%.
no issues - your overall presence and contribution in this forum is something awesome.
